Oil level question for the 6.0L - Ford Truck Enthusiasts Forums
Old 04-19-2011, 09:12 PM
joe blow's Avatar
joe blow joe blow is offline
joe blow is gaining momentum as a positive member of FTE.joe blow is gaining momentum as a positive member of FTE.
I had a few questions for the techs or anyone that might know.
The 6.0L holds approx 15qts of oil with filter.
How many quarts need to be missing for the low oil level light (idiot) to come on?
How many quarts need to be missing for the HPOP to not function properly?
I know this is an odd question but I'd like to know if anyone can share the info....
Thanks
Old 04-19-2011, 11:58 PM
XB70 XB70 is offline
XB70 has a good reputation on FTE.XB70 has a good reputation on FTE.
I don't know. I've never let my oil get that low and I'm not about to drain it out 1 quart at a time to find out.
Old 04-20-2011, 12:06 AM
joe blow's Avatar
I know it is an odd question, but I was asked today and was curious to find out.....figure somebody here might know the parameters of my silly question...if you find out let me know...thanks
PS....probably not worth running your engine to find out
Old 04-20-2011, 01:26 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
I think the idiot light just lights on when the pressure switch turns off. So idiot light = no oil pressure.
Old 04-20-2011, 05:38 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
The full capacity of the 6.0L oil system is around 18 quarts. 3-4 quarts do not drain out in the oil change procedure.
The oil pressure switch activates at 5 psig. So, below 5 psig there is no oil pressure on the gauge. I am like cartmanea - I ASSUME the idiot light comes on then .... but I do not know for sure.
I do not know about the "minimum" oil level for the HPOP to function, but I assume that all is needed is for the LPOP to be able to get suction from the pan and flow the 20 gpm it is designed for. The pan holds about 14 quarts, and I would bet you would have to be VERY low for the pump to lose prime and/or be below the required suction pressure.
Old 04-20-2011, 07:20 AM
joe blow's Avatar
Awesome...thanks guys. It is interesting to know it holds 18qts total
Old 04-20-2011, 08:32 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
ya there is no low oil level sensor. only a pressure swich that makes the light come on.
if your to low on oil it wont run anyway.
Old 04-20-2011, 10:31 PM
IABill's Avatar
IABill IABill is offline
IABill is gaining momentum as a positive member of FTE.
Question
OK so I have to ask is there a hpop reservoir like the 7.3 ?
The reason I ask is I up-graded this week.....
Sold my 02 & bought a 2007 F-350 SRW CC LB Lariat. Pick it up friday.
Been reading the 6.0 page heavy for the past two weeks and have come to one major conclusion....No tuner!!! & Clock Work PM'S
And a 6.0 will live long & prosper........Am I close?
Old 04-20-2011, 10:38 PM
cheezit's Avatar
yes sump is under the oil cooler and cast in to the block. the sump itself holds .89qts of oil.
Old 04-20-2011, 11:06 PM
IABill's Avatar
Question
Guess I should have ask the rest of the question can I suck out the res out with my mighty vac & re-fill like I did the 7.3 or is it not possible or not worth doing?
Old 04-20-2011, 11:08 PM
cheezit's Avatar
you can but its a lot of work to remove that oil cooler
Old 04-20-2011, 11:20 PM
IABill's Avatar
Got It not gona try that.....
Thanks Cheez!!!
Old 04-20-2011, 11:21 PM
joe blow's Avatar
Thanks again guys
Old 04-20-2011, 11:38 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
I'm not sure how much this helps, but I vaguely recall working on a truck that was on my doorstep for a massive external oil leak complaint. This particular truck needed about 5 litres of oil top-up just to bring the level back up to visible on the hash mark on the dipstick. The truck started and ran fine. This particular truck had a massive pressure leak that originated from the top of the high pressure oil pump, the moment the engine was started. I guess that explained why it was THAT low very quickly.
Old 04-20-2011, 11:45 PM
joe blow's Avatar
Thanks Mchan
How many more quarts does 6.0l tranny cooler hold? mrad Excursion - King of SUVs 5 07-11-2012 10:17 PM
How many quarts? Rambo76 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-12-2011 01:13 PM
How many quarts? TEWMUCH 1999 to 2016 Super Duty 1 06-10-2010 11:42 PM
How much oil in 06 4.6L? abah 2004 - 2008 F150 3 07-02-2009 08:28 AM
I need info on my 534 Maximman 401, 477, & 534 SD Engines 5 02-16-2005 07:06 PM
Tags
04, 2007, 60, 60l, capacity, diesel, f250, ford, level, light, low, lpop, oil, pressure, prime
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
