1985 ford f150 4.9 carburator - Ford Truck Enthusiasts Forums
Old 04-19-2011, 07:28 PM
that1dude that1dude is offline
that1dude is starting off with a positive reputation.
i just bought a 85 ford f150, 4.9 carb engine 4 speed tranny, 89,000 miles on the truck ... when i first got it, it was not running, alot of wires had been messed with so i had to wire a push button ignition, after that i drove it, and it felt like it had no power and it would stall out on hills so i adjusted the distributor and got power then replaced the fuel pump and it ran great for 10 mins then the clutch blew... so i changed the clutch and ran perfect for a week... changed the oil drove it around than all of the sudden it stalled it will idle but when i try to go in first gear it feels like its about to die and after about 3 trys trying to catch it in first the 4th time it caught it had no power at and moved like a snail ... so i parked the car where i broke down and the next day came to get it and i fired it up and bearly made it up the hill before it stalled again,the next day i fired it up and it ran perfect again no stalling ton of power so idk... could it be somthing with the timing or do you guys think somthing else is wrong i mean it shifts beautifully and the engine purrs so i dont thinks its the tranny or engine but idk ... maybe new plugs and wires and distriubutor ... any help is appreciated
Old 04-19-2011, 09:01 PM
ebodell's Avatar
ebodell ebodell is offline
ebodell is starting off with a positive reputation.
I believe that your truck originally came with the infamous feedback carburetor. It is somewhat hard to follow from your description but it appears as if the feedback system has been "tampered" with. The best course to take is to search the forum using the keyword "feedback carburetor" or similar and read all you can so you can better diagnose the issue (or issues). Perhaps you could post some underhood shots and likely one of the experience guys/gals will chime in. You may be dealing with a combination of issues (not uncommon with a 25 Y.O. vehicle with an unknown history).
Just remember; the search function is your best friend on the site.
Old 04-19-2011, 10:18 PM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
at this point, your best bet is to swap out all the feedback mess for a traditional carb, unless you absolutely need to be stock for an emissions inspection. this has been written up many times, so i won't waste our time giving the basics again, unless you need help with something
Old 04-20-2011, 01:52 PM
1986F150six 1986F150six is online now
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Welcome to the forum, that1dude!
Look at the top of the page and press the "Search This Thread" blue "button". As ebodell suggested, type in "feed carburetor" or "Duraspark2" and you should find a great deal to read. Good luck!
Old 04-20-2011, 08:54 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
There is a "Search This Forum" link when you're at the forum's front page, too.
1985 f150 300 lacks power Tooleytool 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 10-22-2016 06:57 PM
Engine Lost Power, Then Kept Stalling at Idle Clem's Cousin 1968-2013 Full Size Vans 2 08-24-2016 03:01 PM
ford 1985 f150 300/4.9 np435 dspii conversion 1985tullyhowell 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 173 10-02-2014 03:24 PM
1985 ford f150, 4.9 carb, 4speed transmission POWER PROBLEMS HELP !!! that1dude 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-17-2011 09:24 PM
Help! Fuel Flow Problem? BigSix1 1987 - 1996 F150 & Larger F-Series Trucks 7 12-18-2003 05:18 PM
Tags
1985, 49, 50, 85ford, carburetor, clutch, engine, f150, ford, photos, size, speed, swap, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
