Lost Power Brakes
04-19-2011, 06:22 PM
on
Lost Power Brakes
Coming home last night, raining, Power Brakes just went away, no warning, just gone. Brake warning light came on and stayed on.
What is top culprit?
Booster
Booster check valve
Vacuum Pump
I did go through vacuum lines and did not see in obvious cracks/holes. Also looked at nipples on vacuum block, nothing.
04-19-2011, 06:27 PM
on
mine did that about a month ago,and it was the vacuum pump that went bad
04-19-2011, 07:43 PM
does your A/C controls work if it's a vacuum pump that went out then only the top defrost vent should blow
04-19-2011, 08:06 PM
on
As others have said, vacuum pump. Not hard repair, I've replaced mine 3 times. O'reillys and their lifetime guarantee has been well worth it!
Be careful pulling the pulley, that's the hardest part.
(and getting the darn belt back on)
04-19-2011, 08:43 PM
on
Quote:
Originally Posted by
fordpride
I will check tonight, thanks!
04-21-2011, 06:19 PM
on
I took Booster off, it holds pressure so it must be vacuum pump. I have to order one.
btw- only the defrost vents work, will not select to vent or heat.
04-21-2011, 07:32 PM
go get you a vacuum pump it's done
gearloose1
11-09-2018 07:02 PM
olblue77
11-23-2014 12:54 AM
soondg
Pennsylvania Chapter
09-12-2014 12:34 PM
gearloose1
04-06-2010 09:00 AM
jqp00002
10-14-2007 08:37 PM
