Thermostat Housing
Old 01-06-2012, 08:47 PM
Wriz's Avatar
Wriz
Wriz is offline
Thermostat Housing
Replaced my thermostat today and when torqing the bolts, the bottom bolt hole flange on the housing snapped clean off. Needless to say, I need a new housing.
I went to AutoZone but the one they sold me was casted wrong because I couldnt get a socket or wrench on the top bolt. O'Reilley says their Motorcraft housing is a 2 week order.
Long story short, where and who makes the best replacement housing? Im not looking for fancy (or maybe I am!), just need to be able to drive my Bronco!
Thanks
Old 01-06-2012, 09:32 PM
billt28's Avatar
billt28
billt28 is offline
I might have one in my garage I can give you for shipping. I'll check tomorrow after work.
Old 01-07-2012, 01:02 AM
Ken(Ark)'s Avatar
Ken(Ark)
Ken(Ark) is offline
Thanks
Can you use a bolt with an internal hex that is tightened with an allen wrench ? Those bolts are easly to find at most hardware stores ? Lowes , Home Depo .
Might get you on the road quickly .
Old 01-07-2012, 07:20 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Assuming that you are referring to a 1984...
1984 F150/350, Bronco & Econoline 4.9L (300 I-6): There are TWO different types of thermostat housings, one type is 1984 only / 1985 and later is not the same.
Neither of the following have a Motorcraft part number, just Ford part numbers.
1) EOTZ-8592-B .. Thermostat Housing-Use with unleaded fuel (no, I'm not kidding!) / Obsolete
Applications: 1980/84 F100/350, Bronco & Econoline.
2) E4TZ-8592-B .. Thermostat Housing-Use with leaded fuel / Obsolete
Applications: 1984 F150/350, Bronco & Econoline.
Where in CA are you?
super66
19
04-28-2017 06:08 PM
lamoz
04-24-2017 01:56 PM
nynejoe
07-22-2013 11:38 PM
Dirt Boy
10-14-2009 05:25 AM
49FordGirl
Flathead V8 & Flathead 6
06-13-2009 07:34 PM
Quick Reply: Thermostat Housing
