timing f150 1992 - Ford Truck Enthusiasts Forums
timing f150 1992
Old 03-20-2003, 08:07 AM
jerry595 jerry595 is offline
jerry595 is starting off with a positive reputation.
timing f150 1992
I recently inherted a 92 f150.I failed smog timing out (15 instead of 10). I figured my friend had changed timing for some reason or another. Did adjusment (didn't know what I was doing) and then fail another pretest for emmisions. If anyone has a hard time finding the in-line spout connector try looking on the fire wall on drivers side. The thing is close to the ignition moduel which is not always mounted on the distrib. Ended up there were several other problems that I of course assumed were maintained by prior owner. Plugs way over gapped, one broken & arching, bad plug wires, cap rotor and the last (which I hope is the last) the alt wasn't all there. Aftere hours of work (by a not so dumb female blonde, speaking of myself) I had the thing running great. It died suddenly once. I don't know where to judge timing. With the in-line spout connector out at warm, should you judge the timing by the half moon or the straight arm. I've heard both. I just need to pass smog.
PS if you need to find that in-line spout connector I think I can help. No one I talked to could help me but I recieved good advise from this site!!
Old 07-26-2005, 09:13 PM
lamp210 lamp210 is offline
lamp210 is starting off with a positive reputation.
hello
i just put a new motor in my 92 f150 and need to set the timing.I'am not sure where the spout connector is ? or at least where it plugs in at? i think i have the wire that plugs in, its always been unpluged as far as i could tell?? it comes off the main harness that plugs into the gang plug that bolts togeather on the inner fender drivers side cant seem to find where thi wile plugs in at???
thanks dave l.
Old 07-26-2005, 09:24 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome jerry595 and lamp210, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 07-26-2005, 09:41 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
jerry595 and lamp210, you both need to go out and buy a manual for your trucks. go to an auto parts store and rent or buy a timing light. tell us more about engine, trans and then we can help you more. good luck, and welcome.
Old 07-26-2005, 09:53 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
the timing marks are on left side of the harmonic balancer, there are markings on the right side also but serve no purpose(for timing that is) you will see a little v groove when you actual have the timing light working, that mark is 10 degrees BTDC. It would be wise to mark the timing mark on the harmonic balancer with chalk, make it alot easier to see with the light
Old 07-26-2005, 10:22 PM
95X15 95X15 is offline
95X15 is starting off with a positive reputation.
Timing mark is machined into the crankshaft b pulley about 1/16" wide and runs from front to rear of pulley surface; it is not otherwise marked. the timing scale is located on the passenger side and is visible by looking down past the alternator to the lower part of the front cover; the scale is marked with 0 in middle and goes up and down about 10 to 20 degrees both ways one direction is marked advance Before TDC and the other is marked. Sorry had to get Haynes manual which says V8 scale is engraved into the pulley and mark is stationary; I6 is a notch on pulley and scale is on the cover. I6 scale is marked 0 for TDC, goes 14 degrees BTDC and only 6 STDC; V8 scale goes to 30 degrees BTDC and only 10 degtrees ATDC.
Timing should be 10 degrees BTDC.
I usually get under and mark the scale where I want the timing set with a yellow crayon after cleaning the area to be sure I have the right mark then locate the timing mark/scale on the pulley and mark 10 Degrees BTDC on the scale with the crayon so both are visible when running. The I6 mark is a notch in the edge of the pulley so it has to be filled with crayon so it is visible while moving. Be sure to remove SPOUT jumper GREy plug with two wires at ignition module harness should be Pink wire in and out of SPOUT jumper.
Haynes has diagrams in manual but I couldn't find one in ford manuals.
Hope this helps - if necessary post back with your engine type so can be clearer and more specific.
Old 07-27-2005, 05:17 PM
thanks for the replys, but all i need to know is where dose the spout connector plug in? i have a wire that comes from the main harness that goe's to the terminal block on the inner fender drivers side, it has a two prong plug on one end i think that is for the spout connector? but i can't find anywhere to plug it in it has been unplugeg i beleve for ever?? thanks again.
Old 07-27-2005, 05:28 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
^ I think that is the plug for the power steering pressure switch. If you don't have a 5.0 and a stick shift, you shouldn't have the pressure switch, and the plug will just hang there and not do anything. The SPOUT connector is very close to the TFI ignition module, located on the distributor on earlier EFI trucks, and mounted on the drivers side fender on the later models (at least as early as '92 the TFI is on the fender).
Old 07-27-2005, 05:42 PM
quicklook2's Avatar
95x2 told you all you need to know, including what spout looks like. i again suggest you get a manual or at least go and look at one. it will really help you out.
Old 07-27-2005, 08:33 PM
i do have the 5.0 with an automatic, i guess i just don't know what to look for? a picture would be helpful or a siz e shape and color would help thanks.
oh yeh the pink wire in and out of the spout connector,ok thats what i need to know where is the damm spout connector?
Old 07-27-2005, 08:52 PM
EPNCSU2006's Avatar
The plug hanging loose is not used; it is not where the SPOUT connector goes. The SPOUT is on the fender near the TFI module. It's a plug similar to what you have near the wiring junction, but it will have a plastic piece in the end of it connecting the circuit. The connector is likely gray in color.
Old 07-29-2005, 10:07 PM
Thank You
i found it, but it seems as thou my truck likes to run alot better at 14 deg-btdc as apposed to 10 it seems to be a bit doggy at 10??
Old 07-30-2005, 10:45 PM
EPNCSU2006's Avatar
As long as it doesn't ping, it's fine to run it at 14.
Old 07-31-2005, 10:45 PM
At 14 degees I would run higher octane fuel to avoid pinging.
Old 08-01-2005, 03:45 PM
EPNCSU2006's Avatar
I would run the lowest octane possible without causing pinging.
Strange Behavior When Trying To Set Base Timing tempest411 1987 - 1996 F150 & Larger F-Series Trucks 11 10-28-2015 09:35 PM
Absolutely can not find timing marks on flywheel efrntzl 1968-2013 Full Size Vans 5 09-19-2015 11:12 PM
95 150 with 302 SPOUT problems. dragonsfyre 1987 - 1996 F150 & Larger F-Series Trucks 6 07-20-2013 03:39 AM
in-line spout connector 1949f1 Ranger & B-Series 8 09-05-2008 11:27 AM
Spout Connector Confusion don2007 1987 - 1996 F150 & Larger F-Series Trucks 3 04-27-2008 07:05 PM
Tags
1992, 92, connector, f150, inline, spout, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
