Verify this please- lower ball joints
As I understand it, the
Moog - Ball Joint
Part # : K8695T006
Line: MOOG
Thanks.
Moog - Ball Joint
Part # : K8695T006
Line: MOOG
- Limited Lifetime Warranty
- Front Suspension
- Lower
- Problem Solver
- Oversized Ball Joint
- Fits Control Arm With 1.749 Inch To 1.753 Inch I.D.
- Quantity Per Vehicle: 2
Thanks.
Not sure about the part number, but I got my Moog one from the Oriely's and they fit up (I have a 2004 Heritage, but uppers and lowers...upper all part of the control arm assembly, lowers are just the *****). Rent the ball joint press. I pounded on the lowers for hours and then finally got the press and it took all of 10 minutes. Grease them well and often and there will be little wear. No noise out of mine and I have 70k on them.
It says that it's a "problem solver" ball joint and that it's oversized.
If the hole that the joint fits into is in good shape I don't think you need anything other than the normal replacement part.
I've never seen a "problem solver" ball joint so I'm not sure if there's any other difference.
oversized ball joint for factory control arms
Appreciate your reponse. Based on what OReillys said, the normal sized ones fall right through the factory control arm ball joint hole. This is supposed to "solve" that "problem". The regular sized ones are for when you replace the lower control arm with an aftermarket one.
Doing both lowers tonight so will let you know.
Thanks all, Dan
Thanks all, Dan
abranz
12-26-2016 12:51 AM
birchy
1997-2006 Expedition & Navigator
19
08-21-2009 08:09 PM
