leakdown tester on powerstroke
04-21-2011, 01:20 AM
on
Im going to buy a cheap leak down tester to run a leak down on my 7.3, these things run at 500psi. my compressor only puts on 120psi.
is thing going to be enought to run the test???
04-21-2011, 10:54 PM
on
well now that i think about it seems like it would be pain in the *** to do a leak down on a ford. how would i find top dead center??
Unless i loosen up the rocker arms to let both valves close???? Is it hard to reset the rocker arm tension??
Truck is a 2000 f350
AFhunter
1978 - 1996 Big Bronco
05-09-2016 01:24 PM
ARP2
02-01-2016 04:33 PM
Enomra
06-15-2012 05:50 AM
Gary Lewis
10-27-2011 11:27 PM
64l ,
73 ,
cyinder ,
cylinder ,
ford ,
leak ,
leakdown ,
liter ,
powerstroke ,
recommended ,
run ,
test ,
tester ,
testing ,
v8
