Speed Limiter on 2011 - Ford Truck Enthusiasts Forums
Old 04-19-2011, 12:40 AM
av88tor av88tor is offline
av88tor is starting off with a positive reputation.
Does anyone know if and how to disable the speed limiter on a new F150 with a 5.0 engine. ? Mine cuts off around 93, of course the service depart at my local dealer said they couldn't touch it .
Old 04-19-2011, 03:33 AM
640 CI Aluminum FORD 640 CI Aluminum FORD is online now
640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.
Yeah no dealership will touch it.
However I think your best route is go with a tuner. I beleive someone on this site has videos on youtube of a tuned 5.0L doing over 110mph. And doing it quite easily at that. I would check out the 5.0L specific fourms, I think he has threads there.
He would be the one to talk to about getting a tune and/or taking off your speed limiter.
Old 04-19-2011, 07:56 AM
MCDavis's Avatar
MCDavis MCDavis is online now
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
Quote:
A tuner is definitely the way to go if you want to lift the limiter. Mind you that you are still in a truck, and doing that speed is sketchy and potentially very harmful for those around you.
Anyway. I recently got custom tunes from Mike Butler @ 5 Star Tuning (5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services) He personally has a new 5.0 F150 XL and is making great progress with the tuning of that engine. I suggest giving Mike a call or shooting him an email.
Oh yeah...he's also one of our FTE Sponsors!
Old 04-19-2011, 10:38 PM
Thanks I will check him out
Old 04-21-2011, 10:25 AM
carlsonj carlsonj is offline
carlsonj is starting off with a positive reputation.
does using a tunner void some or all of the warranty?
Old 04-21-2011, 10:45 AM
MCDavis's Avatar
Quote:
Been discussed at length. The short is yes, and yes. But it all depends on what you're trying to get covered under warranty.
A bad door switch is likely to be covered if you have a tuner, but a shot transmission if you have a tuner is an entirely different ordeal. Depends on the dealer and how hard they wish to look for the re-flash when you installed the tuner.
The search function will help you find more reading material.
Old 04-21-2011, 09:12 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
I always put my '05 back to stock when it went to the dealer, but the thing is, if they look into your computer and see your truck went 120mph and fuel, air and timing was far off of stock values, warranty will be null and void.
Old 04-22-2011, 08:08 AM
msgtord's Avatar
msgtord msgtord is online now
msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.msgtord has a great reputation on FTE.
Always keep in mind that the top speed on vehicles is set based on the ratings of the tires. It's cool to have a truck that will do 130 mph, but if you don't have the speed rated tires, your really taking a big chance.
Does Ford have built in speed limiter on Trucks waiter21 1999 to 2016 Super Duty 49 07-29-2015 10:47 AM
2012 Ford Explorer Speed Limiter Danish Haidri Explorer, Sport Trac, Mountaineer & Aviator 4 11-21-2012 05:42 PM
Ford Lightning GEN 1 top speed Deutz_F100 1987 - 1996 F150 & Larger F-Series Trucks 19 11-15-2010 06:50 PM
Speed limiter shuts off fuel at what speed? Wagion 1999 to 2016 Super Duty 4 05-18-2010 07:05 PM
Removing Speed Limiter MKJRH 00 6.4L Power Stroke Diesel 3 09-10-2008 09:22 PM
Tags
2007, 2011, disable, f150, ford, govener, limiter, limitor, model, raptor, removing, sho, speed, top, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
