1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Military 37/16.5 tires on F-350
Old 04-21-2011, 04:37 AM
spinella's Avatar
spinella
spinella is offline
i dont...but i did just measure a set of 16.5" x 9.75" wide rims in my garage. they are 16" wide at the bead & 15" wide nearest to the hub. so if your brake assembly is smaller than 15" you should be o.k.
Old 05-19-2011, 05:13 PM
NJSuperduty's Avatar
NJSuperduty
NJSuperduty is offline
wheels
did u ever get a set of 16.5 wheels, I have a set that i am going to sell
Stu
Old 01-06-2013, 09:53 AM
pink_horse_sho's Avatar
pink_horse_sho
pink_horse_sho is offline
Hummer tires
I run the goodyear hummer 37x12.5x16.5 on my 2000 F-250 V10. I love them they do rub when turning even though i have a 6 " lift. The only thing i will say ask if they check for hole or cuts. I ordered 4 for 600.00 that was with shipping. I took my truck to the shop and they put on 2 fine. The third one had a cut but it was a slow leak. The other had a hole big enough for my to put my finger in it. I had to call the place i bought them from finally they sent me two more. But my truck had to stay at shop for two days. They mounted the one with the hole and parked it next to the shop. It would not hold air but they could get enough in it to get it back in. Was not happy about having to leave my only vehicle. The guys at the shop were great. They got the others on and on my way. All is great. My truck looks great no more match box tires. I'm very happy with the tires. They have alot of tread left even after a year of daily driving and trips to AR this year.
Old 10-03-2014, 08:00 PM
marktripp's Avatar
marktripp
marktripp is offline
So would these not work with a 3.5" lift?
Old 10-03-2014, 08:01 PM
marktripp's Avatar
marktripp
Would these rims work for the 16.5" military tires?
http://www.ebay.com/itm/Pro-Comp-Wheels-52-65987-Steel-Wheel-Series-52-16-5x9-75-Gloss-Black-8x170mm-/301154629534?pt=Motors_Car_Truck_Wheels&hash=item461e36f79e&vxp=mtr
Old 10-05-2014, 12:47 AM
Joe Bloomingdale's Avatar
Joe Bloomingdale
Joe Bloomingdale is offline
I have the BF Goodrich Military Baja radials 37x12.5x16.5, 600 bucks for the set and they balanced,
with no problem and ride great. I have a 6.5" lift with no rubbing problems.
No way this tire or any other 37" tire will fit under a whole lot less without some fender mods.
Old 09-16-2019, 09:06 AM
CHAD BURTON's Avatar
CHAD BURTON
CHAD BURTON is offline
I have 2002 7.3 with the same lift and im running that military tire set up and they do amazing off road and improved my interstate mpg but they wear down quickly and have bad traction on wet roads like all mud tiers the sound awesome doing burn outs
Old 10-08-2019, 10:05 PM
moymurfs's Avatar
moymurfs
moymurfs is offline
Regardless of lift..
The calipers just fit with the 17" rim. 16.5" are too small. They will on the earlier trucks but Ford made the brakes larger, needing that 17" rim.
Josh Ludwig
46
04-09-2023 12:32 PM
RJ sheedy
19
11-20-2016 08:26 PM
RJ sheedy
18
11-18-2016 04:45 PM
rustyleerusk
08-22-2015 11:58 AM
Moundainner
30
06-22-2014 08:12 PM
Quick Reply: Military 37/16.5 tires on F-350
