Cigarette lighter wiring question. - Ford Truck Enthusiasts Forums
Old 04-18-2011, 09:56 PM
Highboy74's Avatar
Highboy74 Highboy74 is offline
Highboy74 is starting off with a positive reputation.
'74 highboy and I was looking at why my cigarette lighter wasnt working. Well, after further inspection someone cut the wire. Does anybody know where it plugs into or where it ties into. I want it to use for my radio because I know it is a constant "hot" lead.
Old 04-18-2011, 10:00 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
There should be a 3-connector pigtail hanging behind the glovebox. The cigarette lighter should plug into one of these spots.
The wiring for the pigtail itself is GREEN with a YELLOW stripe. GREEN with a YELLOW stripe is hot-at-all-times power for the courtesy lamp circuit. I use this for the constant power to my radio as well.
Old 04-18-2011, 11:45 PM
Highboy74's Avatar
I saw the wire your talking about, however, I didn't see the pigtail your talking about. I saw an empty single pigtail with the green and yellow wire and another green wire. The cigarette lighter wire is solid black and routed over to the drivers side area over the steering column (factory style).
Old 04-19-2011, 09:51 AM
76F15OSuper's Avatar
76F15OSuper 76F15OSuper is offline
76F15OSuper is starting off with a positive reputation.
Quote:
Originally Posted by fmc400 View Post
T
A little Funny , In my bushiness (Industrial controls) A Green/Yellow wire is GND. I wish wire colors where the same across the board.
Old 04-19-2011, 03:32 PM
73FOMO's Avatar
73FOMO 73FOMO is offline
73FOMO is gaining momentum as a positive member of FTE.
Green/Yellow should be the cigarette lighter wire color. It ties into the circuit with the glove box switch and lamp, door jamb switches, and dome lamp...which run through the green/yellow wire at the headlamp switch. All are powered from the green/yellow wire coming from the 15a fuse in the fuse panel.
Old 05-20-2011, 11:09 PM
Ryank78shortbed Ryank78shortbed is offline
Ryank78shortbed is starting off with a positive reputation.
Anybody know what the black with yellow stripe wire behind the instrument cluster is it has three plugs in it? And what circuit is it on!
Cigarette lighter installation ideas Frmnsal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 06-23-2016 01:57 PM
89 F-150 xlt Lariat Horn will not work Thurisaz 1987 - 1996 F150 & Larger F-Series Trucks 9 02-06-2011 05:40 AM
1997 F-250 LD power outlet / cigarette lighter ten70man 1997 - 2003 F150 1 11-11-2010 01:12 AM
cigarette lighter fuse blowing!! 5.4f250sd 1999 to 2016 Super Duty 9 11-10-2010 09:45 PM
Cigarette lighter install phurst 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 38 06-17-2010 03:16 PM
Tags
100, 2003, 66, 77, cigar, cigarette, circuit, color, expedition, f150, ford, lighter, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
