Instructions for 292 motor valve adjustment!! Any help is desperately needed!!!! - Ford Truck Enthusiasts Forums
Old 03-20-2003, 01:32 AM
292motor 292motor is offline
292motor is starting off with a positive reputation.
Lightbulb Instructions for 292 motor valve adjustment!! Any help is desperately needed!!!!
I have a 292 in a 1963 4 x 4 truck, and I am needing to know the proceedure on a valve adjustment and timing! I really could use some help learning the steps. I am engine literate, and know most car engines. I just bought this classic 63 and am not familiar with it's motor yet.
THANKS SOOO much, you can email me any attachments or scans if neccessary at scottylove123(No Email Addresses In Posts!).
Need new y block flywheel for 292! 500Dave Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 1 05-31-2013 09:44 AM
Help with 292 Broken Flywheel!! 500Dave 1957 - 1960 F100 & Larger F-Series Trucks 7 05-15-2013 12:43 AM
1964 292 transmission wags64 1961 - 1966 F-100 & Larger F-Series Trucks 19 06-08-2006 02:53 PM
292 Y Block-Valve problems & Performance palomino73 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 10 06-07-2006 06:09 PM
292 vs. 312 idaho211 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 1 01-12-2004 02:24 AM
Tags
1963, 292, adjestment, adjust, adjusting, adjustment, adjustmentr, engine, ford, manual, motor, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
