4.9 interchange questions
Hi guys new to the forum. Just a few 4.9 questions. I have a 87 4x4 with 4.9 and want to rebuild a 4.9 out of a 92 will the basic long lock swap with no issues? The motor mounts look different. Also the 92 was a automatic the 87 a manual. Any issues installing a pilot bushing in the auto crank?
Welcome to FTE. Sorry you haven't gotten an answer with 145 views.
Everything should be fine as far as I could tell. No idea about mount differences since this is one of the most unchanged engines ever put out.
If nobody else pops up, you might check in the 6 Forum:
https://www.ford-trucks.com/forums/forum52/
I have a 92 block in my 89 F250. The long blocks are the same for all EFI engines. Engine mounts are year dependent so swap over engine mounts from old engine to the other one.
On my 89 I did swap from V8 to I6 so I had to swap the frame perches and used the 92's.
Here's a link: https://www.ford-trucks.com/forums/1...e-perches.html
Apollo2112
07-27-2009 12:14 PM
klatt_89
01-15-2006 12:20 PM
