71 400 rv cam dyno
Old 04-18-2011, 06:44 PM
justforkicks's Avatar
justforkicks
justforkicks is offline
71 400 rv cam dyno
i have a 71 400 out of a 72 mercury (pulled the heads and checked, definitely a 9:1 compression motor) and i was wondering if anyone has a dyno sheet of this motor with an rv cam, edelbrock dual plane intake, 600cfm carb, and long tube headers. this is pretty much the build i plan and i want to know what most of them run with no overbore and no regrind on the crank.
Old 04-19-2011, 01:06 AM
smokeyb97's Avatar
smokeyb97
smokeyb97 is offline
I have a build that's similar, except mine has a .030 overbore. It has a 9.3:1 compression, mild CompCam 255DEH, Edelbrock Performer intake, Edelbrock 600cfm and long tube headers.
Old 04-19-2011, 10:42 AM
justforkicks
damn them are some pretty good numbers! did you have to run 93 octane or could you get away with running midgrade without predetonating? also, how's the gas mileage with it?
Old 04-19-2011, 02:10 PM
smokeyb97's Avatar
smokeyb97
Thanks, the engine builder and myself were pleasantly surprised with the outcome.
I have to run 93, even before the 351M was rebuilt I had to use premium fuel to keep it from pinging. I'm now getting 12.5 - 13 mpg, before it was getting around 10 - 11 mpg on a good day.
Old 04-19-2011, 02:13 PM
justforkicks
not bad. i was thinking of getting a summit cam with a slightly higher lift and slightly longer duration. do you think it would hurt the mileage much? i know these aren't exactly gas sippers, but if i end up driving the truck longer than expected, then i'd like to at least keep some money in my pocket haha.
Old 04-19-2011, 03:00 PM
smokeyb97's Avatar
smokeyb97
It might hurt fuel consumption a little, but I've said before if you're concerned with fuel mileage, you better not drive these old trucks very much. With the price of fuel nowadays I just use my truck to pull my boat occasionally or haul some dirt , lumber, etc. when needed. It's to costly now to just get out and tool around in anymore, especially @ $80.00 a tank full.
Joel Cassell
18
05-11-2018 11:31 PM
TMI
39
10-27-2008 01:31 PM
riverdog
07-24-2007 11:20 AM
fordguy76
08-01-2006 03:14 PM
sugar
12-19-2003 01:10 PM
Quick Reply: 71 400 rv cam dyno
