Dual controls F-Superduty- Got it, doing 4x4 conversion...
#61
when you say TRUE D80's ARE MUCH TOO LARGE TO FIT THE STANDARD 8 LUG PATTERN , what the heck did a true D80 come on ? all i have seen is the D80 in the Dodges with the 8x6.5" pattern and the D80 in the older Fords F450 with the 10x6.5" pattern ! i do believe that the Fords used the 10x6.5" , had a couple at work but never got any tape measure out !
#63
This is where the glove box should be. The bottom-left of the opening was all cut away to make room for the steering cross-shaft...
Uploaded with ImageShack.us
#64
on
Try this:
Rear Axle FORD 8-lug Hubs
(2) Rear Axle Ford 8 lug (6.5" BC) full-floater hubs
Part #F6UZ-1109-AA
They are new in the box, never used hubs that include new Timken bearing races already installed by the factory.
Will fit DANA 80 axles that came factory installed in E450 vans and perhaps some other applications.
$300 for both, or best offer
Oh yeah, not mine.....
Part #F6UZ-1109-AA
#65
#67
#68
#69
#71
LOL- yeah, it's tough to build a treehouse when all you have is pine trees...
I put beams between 2 trees, with slotted holes so the trees could move when it's windy, and built an 8x12 platform on it. The A-frame roof has panels that open for windows. (great for water balloons...) I always meant to do a suspension bridge to the house, but never got around to it.
#73
Oh, nothing too serious. I just hit my frustration limit today after I found that I gotta change out all the heater ductwork. None of the vacuum operated doors work, & most of the vacuum lines for them were cut out... I don't know why they butchered it up, but it's a mess. At least I figured this out before I put the dash back in.
#75
