E3 plugs
E3 plugs
Hey guys just drove home my 06 f250 v10 on thursday. So far Im getting 10.5mpg. thats about what I expected. Talking to a few locals they have told me to change the plugs with the E3 Diamond fire plugs. Supposidly I can see a difference in mpg and performance. Has anyone used these.
thanks
gg
thanks
gg
Which is because Autolite makes the Motorcraft plugs
I once went into this a while back, researching each manufacturer's plug, all of types.
There are basically a few different types of "platinum" plugs.
First is plain "platinum" which is what our mod motors use stock. It has a platinum wire inside the main center electrode or the center electrode is tipped with it, and the ground electrode is plain steel.
Second is "double platinum" which means both electrodes use platinum, I think the ground electrode is just "tipped" with it.
There are more exotic versions too, I think one has a full platinum center electrode, and a bunch of other weird stuff.
The problem stems from the platinum having different electrical properties, so even double platinums take more volts to get a spark from. Which can play havoc with the COP coils.
Technical spark plug information: sparkplug charts, cross reference, iridium and platinum information
E3 plugs are total marketing tripe. The plugs themselves are cheap chinese junk.
New plugs will always give improved mpg if the old ones you compare them to are grossly overdue. That fact is what the snake oil gee-whiz-bang plug marketers rely on.
A brand new Motorcraft plug will give you the same result, or possibly even a bit better result.
NCMODELA
23
11-12-2015 03:42 PM
1800joedaddy
33
02-06-2012 08:52 PM
