Freeing your stiff u-joints with no zerks - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 04-18-2011, 03:47 PM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
I know there will be nay-sayers but there are 2 ways to free up those nearly frozen, dried up, front u-joints with no zerk fittings in your 4WD.
1; Take your truck to an empty parking lot, lock your front hubs, spray 1 joint with penetrating oil, make a bunch of full lock turns, do other side. Turn and spray until they quit jerking, crunching, and clacking.
2; Rip a couple strips from an old towel about a foot long, lock your front hubs, soak the rags in ATF, string them through the front joints and tie them in the back, drive with them for a day or 2. You can add oil the second day also.
This will rejuvenate dried up joints that still have grease residue in them but are still in good shape. These joints don't normally get used much and also get water in them. I have done both these methods and they both worked; saving my joints.
2005 4x4 Excursion, new ball joints... and the zerk fitting dilemna JohnnyAirtime Excursion - King of SUVs 8 04-14-2016 06:43 PM
Lube your u-joints with no zerk fitting installed EXv10 Excursion - King of SUVs 34 11-09-2013 06:16 PM
04 4wd front end grinding when turning 77f250sc 1999 to 2016 Super Duty 0 05-21-2012 01:52 PM
Don't laugh but you can free those frozen U-joints....... EXv10 Excursion - King of SUVs 32 09-02-2011 09:19 PM
Properly Seated Ball-Joint? and other ?? cjcocn 1999 - 2003 7.3L Power Stroke Diesel 9 04-09-2009 09:46 AM
Tags
diesel, ford, forum, free, frozen, joint, joints, moves, real, spraying, stiff, ujoint, ujoints, universal, zerk
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
