A/C clutch or bearings? 98 250 5.4
Old 04-18-2011, 11:54 AM
leforrest's Avatar
leforrest
leforrest is offline
Hey guys.
My air conditioning compressor is rattling and grinding. Im trying to determine if I need a whole new unit or just a clutch assy. I can say this, when running it's rattling, but when the clutch engages, it clears up.
Would I be right in assessing it's the clutch?
...or am I better off buying a cheap compressor unit off Ebay? There are some remans on there reasonably priced.
Thanks all!
Old 04-18-2011, 06:54 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
its the bearing or clutch- magnet clearance setting........ once it locks up the bearing and clearance are gone, only the internal compressor is working.
Old 04-18-2011, 07:43 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
You'll need a new clutch plate at a minimum...
Old 04-18-2011, 07:48 PM
leforrest's Avatar
leforrest
Thanks.
Should I just buy a new clutch assy? or just buy another compressor?
Old 04-18-2011, 09:23 PM
steve(ill)'s Avatar
steve(ill)
clutch assembly would do it.. compare the price to a unit.
Old 04-19-2011, 04:59 AM
leforrest's Avatar
leforrest
Thank guys. There's a reman on ebay for 89 bux...also a clutch assy for 45 ish. Guess its a toss up. Although for 45bux I wouldn't have to worry aabout coolant loss or recharging....hrm.
Old 04-19-2011, 06:54 AM
projectSHO89
Before ordering anything, do the following:
1) Inspect the clutch plate. You'll likely find it has separated.
2) Remove the serpentine belt.
3) Remove the clutch plate.
4) Spin the pulley by hand to see what the condition of the bearings might be.
If the bearings are rough, replace both the pulley and the clutch. USE ONLY A MOTORCRAFT CLUTCH PLATE unless you can easily return the parts . Pulley and bearing are under $100 from forum sponsor Rockauto. Both can be replaced in-vehicle without having to mess with the sealed refrigerant system.
Old 04-19-2011, 07:56 AM
paker's Avatar
paker
paker is offline
It's always a toss-up between the whole compressor-clutch assembly and just the clutch. Mileage of the compressor is a factor.
Old 04-19-2011, 12:27 PM
projectSHO89
I don't believe it to be a tossup for most people.
If you're limited in mechanical skills and equipment, a clutch and/or pulley can still be done. Replacing a compressor is out of the league of most DIYers due to specialized equipment and skills that are needed to do it right. If someone has to pay a shop to replace a compressor, you're probably looking at a $500-700 repair.
Old 04-19-2011, 12:33 PM
leforrest's Avatar
leforrest
Thanks PSHO.
I was referring to more of a toss up financially. Didn't know if I should go the whole compressor replacement route. I think I am going to follow your advice though and look more into the clutch assy to preserve the coolant.
Old 09-25-2013, 03:05 PM
Warbird66's Avatar
Warbird66
Warbird66 is offline
can't get ac pulley off
OK, had similar problem with AC grinding. With power on and AC on in cab, I could tell the magnet was not engaging. Got everything off and checked the bearings by spinning the pulley (very wobbly). Now the problem is that I can't get the pulley off (WTFO) - after everyone has indicated that it should just slide off. It seems to be getting hung up on something.
While I've seen some replies that "some well placed screwdrivers" will help pry it off, even that didn't work and I don't want to go too far and ruin the compressor. Any suggestions?? Do I need a pulley remover, and if so, what type will work?
Thanks in advance - Mike
tjc transport
03-24-2016 04:15 PM
croutman1
1997 - 2003 F150
11-13-2015 09:54 AM
dblott1
1999 to 2016 Super Duty
06-22-2015 11:50 AM
Nathan A Kidder
Modular V10 (6.8l)
07-10-2014 05:25 PM
texaskid22
02-21-2011 10:36 AM
Quick Reply: A/C clutch or bearings? 98 250 5.4
