1999 f150 4x4 5.4l motor question
Old 09-22-2013, 11:47 AM
Bobbycolt's Avatar
Bobbycolt
Bobbycolt is offline
I've got a 1999 f150 4x4 5.4l triton and was wanting some info on the motor I more or less want to know what the motor was designed for ( more for speed(hp) or pulling (torque)) had argument with a chevy fan and didn't believe me so wanting to get things straight thanks
Old 09-22-2013, 06:47 PM
vaper's Avatar
vaper
vaper is offline
To answer this you need to know the relationship
between HP and torque
Torque is a measurement
HP is just mathematics
Torque x rpm divided by 5252 = HP
Here is a good read to put to rest all the myths regarding hp and torque
Power and Torque: Understanding the Relationship Between the Two, by EPI Inc.
Old 09-23-2013, 10:27 PM
Bobbycolt's Avatar
Bobbycolt
Thanks that helps me a lot. doesn't really matter to me anyways as long as it does what I want lol.
Old 09-24-2013, 10:08 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Hi Bobby.
Another position is the application, and the displacement.
Without compare in a fair manner it has little value for just debate.
The engine designs are vastly different to boot.
A compare on the basis of HP and torque at their given RPMS is a reference to start with.
Some examples are the 5.4L over head cam converted to cubic inches = close to 330.
The usual GM size if already 350 cu/in.
There is you first parameter.
The larger displacement usually produces more torque on the average but is dependent on how well the two motors breath air.
The GM being a push rod motor and larger 'may' not still breath as well as the smaller overhead cam Ford.
The name of the game is how much air can be pumped at the same rpm for both motors at different parts of the rpm band.
You can begin to see how complicated it can get debating with another who may not also take these performance parameters into account.
One more difference is the application.
The same motor in a car may not be cam profile timed the same as for a truck application and so produces different values of torque at different rpms.
I will stop here because the subject can take up a whole book.
Hope it adds some to the question.
Good luck.
r_reed
10-09-2018 06:48 AM
jhromy
01-09-2004 09:17 AM
Will Stewart
Garage & Workshop
11-12-2002 11:00 AM
karljay
Offroad & 4x4
03-08-2001 12:49 AM
bcf150
02-26-2001 05:18 PM
Quick Reply: 1999 f150 4x4 5.4l motor question
