Confirmation of FDM crossover problem? 1991 F150 5.8 - Ford Truck Enthusiasts Forums
Old 04-18-2011, 12:47 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
So one item on my to do list is to drop both fuel tanks, clean them up and repaint. Since I suspected the front tank of having a leak, it came first. I got around to dropping it last night.
I couldn't find anything that would fit tight/exactly into the fuel lines, and since I figured the plug was more to keep dirt out, I used a bolt that fit closely and taped it in place [as I didn't have any hose clamps available.
Went to start the truck after everything was buttoned up and it would turn over, almost fire, but not start. Then I noticed the ever present smell of gas. Got out, looked underneath, and found what must've been a half gallon of gas on the shop floor.
So this time I turned on the key, but not to start, and looked and sure enough, fuel was practically pouring out of one of the lines. I didn't have a choice but to kink the line and tape the crap out of it as I didn't have any other materials to properly plug the line.
So I'm just wondering, with fuel dumping out of one line to the front tank when the rear is selected, is this confirmation of the FDM crossover problem, or would it have to be dumping out of both lines?
Old 04-18-2011, 02:13 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Has nothing to do with the crossover problem, that fuel crossover problem is a bad valve inside the tank.
What you have is normal.
Old 04-18-2011, 02:18 PM
DBGrif91's Avatar
Okay... so, for the sake of learning a thing or two, why is fuel coming out of the front tank line when the rear pump is activated?
Old 04-18-2011, 02:22 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
The front tank check valve is not there, it's in the tank you removed... Remember?
Quote:
Old 04-18-2011, 03:09 PM
DBGrif91's Avatar
Quote:
Hehe... yes, I remember. I guess I didn't realize the check valve was inside the tank itself- I guess I've just been confusing myself.
Old 04-18-2011, 03:32 PM
I just couldn't help myself.. You left yourself wide open and this old smart a$$ jumped all over it!!!!!
Does it have a fuel selector valve or not?? Jonnys.1991 1987 - 1996 F150 & Larger F-Series Trucks 5 04-11-2016 09:18 PM
1990 F250 hot hard start/low fuel pressure? tsalley55 1987 - 1996 F150 & Larger F-Series Trucks 4 08-25-2015 09:03 AM
Fuel Pump Blows Fuse :( TheKhaos 1987 - 1996 F150 & Larger F-Series Trucks 6 06-21-2013 02:04 AM
'92 f150 6cyl, fuel pump runs constantly (intermittent) lralston01 1987 - 1996 F150 & Larger F-Series Trucks 41 01-10-2011 07:58 PM
1990 F150 dual tank wiring Pollak valve Patman-TX 1987 - 1996 F150 & Larger F-Series Trucks 34 12-09-2010 02:45 PM
Tags
1991, 1996, 58, check, cross, crossover, dumping, engine, f150, f250, fdm, ford, front, fuel, tank, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
