Fuel pump issues - Ford Truck Enthusiasts Forums
Fuel pump issues
Old 04-18-2011, 10:04 AM
mduncan mduncan is offline
mduncan is starting off with a positive reputation.
Exclamation Fuel pump issues
I have a 1992 F-150, with duel tanks. I have never had any fuel problems. I drove to the job on Saturday, went to move truck 20 minutes later, and it would not start. I have good spark. I changed fuel filter. When turning on key, the fuel pump kicks on for about 1 second. I checked the other tank, and it does the same. I removed the fuel filter, then turned on the key, and it barely has any fuel coming through the line. Please help. The odds of both pumps going at the same time has to be nill. I am out of ideas. I also checked the relay. I checked the reset inside the kick plate, and i assume that it was not tripped, as I could not push it in. HELP!!
Old 04-18-2011, 10:39 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like you are out of fuel in both tanks.
OR someone has squeezed the fuel line closed after the "T" on the frame and before the fuel filter.
Old 04-18-2011, 11:07 AM
Have fuel. Where would this T be located? Near the rear of the front tank?? Also why would this be a problem, when it seemed to be running fine before. Did not hit anything, only been on paved roads.
Old 04-18-2011, 12:18 PM
subford's Avatar
Both fuel tanks pump in to this "T" on the frame near the front tank and there is not anything from the "T" to the injector filter except a tube of about 2 ft or less long.
Your fuel system:
The "T":
Old 04-18-2011, 12:39 PM
Thanks, I will give that a good checking. It looks like a compression fitting, am I correct in assuming that? And do I need any special tools to take this apart?
Old 04-18-2011, 12:43 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
I like the carpet Bill...
-Wes
Old 04-18-2011, 12:48 PM
subford's Avatar
The "T" does not come apart.
Old 04-18-2011, 01:51 PM
Should I just tap on it, and see if I can dislodge anything in there?
Old 04-18-2011, 02:07 PM
subford's Avatar
No, I would disconnect the supply fuel line from one of the tanks and turn the key on and off one time and see if you get any fuel out of the pump.
I do not think any tapping would do you any good.
You will need a short hose and a container for the fuel to run into.
Stick the hose on the tube coming out of the pump.
If you do not get any fuel then and you hear the pump run you will need a new fuel pump.
I have never heard of your problem before and it does not seem possible.
Fuel Question chaser1602 1987 - 1996 F150 & Larger F-Series Trucks 3 02-14-2015 05:24 PM
No Fuel pressure DrFord Ford Inline Six, 200, 250, 4.9L / 300 7 10-20-2013 10:46 AM
Zero fuel pressure... GotThreeOfThem 1987 - 1996 F150 & Larger F-Series Trucks 9 07-10-2013 06:58 AM
2001 Ford Expedition 4.6L XLT Cranks but won't start - fuel pump or ??? Jymmm 1997-2006 Expedition & Navigator 7 02-01-2013 05:53 PM
Fuel Pump MrJames159 1997-2006 Expedition & Navigator 12 11-11-2010 09:15 PM
Tags
1992, 73, 97, comeing, filter, fuel, fuil, lit, supply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
