how to change fuel filter? - Ford Truck Enthusiasts Forums
Old 11-12-2014, 07:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Fuel System Guides
Print Wikipost
Old 04-17-2011, 10:01 PM
93 mix 'n match's Avatar
93 mix 'n match 93 mix 'n match is offline
93 mix 'n match is gaining momentum as a positive member of FTE.93 mix 'n match is gaining momentum as a positive member of FTE.
how do i change my fuel filter? i was told certain tools were needed?
Old 04-17-2011, 10:18 PM
fordf150farmer's Avatar
fordf150farmer fordf150farmer is offline
fordf150farmer is starting off with a positive reputation.
How To's on changing fuel filter? - F150online Forums
every thing you need right here ^^^
any auto parts store should have the tool you need like 5 bucks for the package
Old 04-17-2011, 10:29 PM
sport truck xl sport truck xl is offline
sport truck xl is starting off with a positive reputation.
fuel line removal tool at any auto parts store they run about $8
Old 04-17-2011, 11:00 PM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
I didn't read the full 6 pages on the "How To" link but you should relieve the fuel pressure first before attempting to change the filter. 45 psi 'approx' fuel pressure can do harm to you if it hits your face, eyes, hot exhaust pipes, etc. Just pull the fuel pump fuse, crank the engine over a few seconds, it won't start. Turn key off, reinstall fuse, change your filter. Even after relieving fuel pressure there will be residual fuel in lines leaking when removing the filter, so have rags handy and be safe.
Old 04-18-2011, 09:52 PM
so, new problem. cant get the lines off. got the tool, it slides in, but they lines wont pop off!! i can twist them, but they just wont pop off.
Old 04-19-2011, 10:10 AM
meierw1's Avatar
meierw1 meierw1 is offline
meierw1 is starting off with a positive reputation.
Quote:
Had the same problem with mine, take some wd or pb blaster and spray it in the ends and sit there and work it slowly or you woll end up breaking the line and having to replace it.
Old 04-19-2011, 11:48 AM
jgeese jgeese is offline
jgeese is starting off with a positive reputation.
From my experience the plastic tools don't work very well. Asked at the parts store for something more substantial and they had a metal tool that looked like scissors that had a shaped cup at each end to fit over the fuel line with each end a different diam. Gives far more leverage and something to push with in tight quarters!
Hope that helps...
Old 04-19-2011, 04:07 PM
I agree, use the metal tool and just use steady pressure pushing on the tool with one hand and pulling the fuel line with the other.
Old 04-19-2011, 09:18 PM
what size is the line so i know what size to get?
Old 04-19-2011, 11:47 PM
Sometimes there's dirt/rust forms inside the connection. Try spraying it out with wd as suggested above. In a kind of awkward movement for one hand, I have the tool positioned on the line, then I try pushing the line into the filter, then I press the tool into the connection. I then tug/twist on the line with the tool still pressed in while holding the filter with the other hand. I have used both the nylon and steel scissor tool as mentioned in other reply but prefer the steel tool better.
The scissor tool is made for two different line sizes.
Filter change brother steve 6.7L Power Stroke Diesel 15 10-29-2015 03:24 PM
How many miles should I change oil and fuel filter Bvill01 1999 - 2003 7.3L Power Stroke Diesel 21 10-09-2012 07:41 AM
Fuel Filter Change Interval '94IDITurbo7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 03-08-2012 11:14 PM
Fuel Filter Change? How Often? bebeard 1999 to 2016 Super Duty 7 12-15-2011 12:34 PM
Can't Get the Fuel Filter Out?!? 94MustangGT 1987 - 1996 F150 & Larger F-Series Trucks 6 08-08-2008 03:18 PM
Tags
1997, 2000, 2003, 2011, 54l, 67, change, changing, expedition, f250, filter, filters, ford, fuel, instructions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
