EGR Problem? - Ford Truck Enthusiasts Forums
EGR Problem?
Old 04-17-2011, 10:01 PM
mrgn_mtt's Avatar
mrgn_mtt mrgn_mtt is offline
mrgn_mtt is starting off with a positive reputation.
Question EGR Problem?
Hi I have a 1996 F150 with the 4.9 and a 5 speed. For the past couple years the check engine light has been on. I know its nothing and I could care less about fixing it. But here in CA it won't pass with that light on. Apparently this code involves the exhaust and cats. From what I have been told, it may be because I put a less restrictive exhaust (Magnaflow) and that is giving it a different reading than stock. I have also been told that it may have something to do with the EGR. I just want to know what it might be and how to fix it. Last time I got it fixed to get slogged he said the EGR was clogged.
Old 04-17-2011, 11:21 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
A list of the error code(s) would be most helpful in order for someone to help you out here.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
