86 F-250 351w... What holds fuel pressure in the line going to the carb? Is it the fuel pump (mechanical)? The truck cranks; I see fuel pumped to my inline filter. As soon as it's pumped;it drains back out. Any other causes? Thanks.
Fuel pump does hold the gas in the line. If the filter is not completely full all the time, don't worry about it, a air pocket can get trapped in it sometimes.
I figured the fuel pump was the problem. I crang the truck over using the hand held trigger and as soon as fuel goes into the filter it drains out with each crank of the motor.
