99 Ranger Hood stuck closed can't open
Old 04-17-2011, 06:40 PM
snorindad's Avatar
snorindad
snorindad is offline
Just purchased a 99 ranger Friday. Just got home from a backpacking trip and my son tells me the hood wont open. Looking for suggestions on how to get it open can barley see the latch between the grill and hood. but there must be a way but I can't think of it right now. Any help would be appreciated. Thanks
Old 04-17-2011, 07:51 PM
justforkicks's Avatar
justforkicks
justforkicks is offline
is the hood latch inside the cab releasing the hood? or did the cable snap or what?
Old 04-17-2011, 07:53 PM
snorindad's Avatar
snorindad
cable does not appear to be broken but it does seem to be stretched. Tried to pull cable and at same time pull up on hood but no luck.
Old 04-17-2011, 07:55 PM
snorindad's Avatar
snorindad
While I was gone my son and a friend tried to get it open and I think they pulled to hard on the cable.
Old 04-17-2011, 07:56 PM
justforkicks
i'd say pull the hood release off and pull on the cable end with pliers or vice grips.
Old 04-17-2011, 07:59 PM
snorindad's Avatar
snorindad
Are you saying to pull it from inside the cab? or is there a way to get a hold of it through the grill?
Old 04-17-2011, 08:04 PM
greenpus's Avatar
greenpus
greenpus is offline
I'm sure you already know this but the cable release in the cab only unhooks the hood. The safety latch on the hood still has the hood locked down. You have to push your fingers inside the engine compartment and move the lock to the left and then the hood will open fully. But I'm sure you already know that
Old 04-17-2011, 08:05 PM
justforkicks
well, i don't really know because my grill's already busted out so i can see mine plain as day. pulling the hood release inside off is less labor intensive and you'll know right away what's wrong with it. you may be able to get tools in from under the bumper in between the grill and radiator but go from inside the cab first because that'll tell you whether the cable's stretched, broken, or your release lever might just be screwed up. if the release mechanism itself is broken, you'll have to try and sneak in a pick or something to slide the release over to get the hood open.
Old 04-17-2011, 08:17 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
A bit of a longshot, but try pushing down on the hood while someone is pulling the release inside. It could just be jammed from being adjusted too tight.
Old 04-17-2011, 08:57 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
Like the above post says. It takes two people to open sometimes. Push down on the front edge of the hood 20-30 pounds of push then have somebody pull the inside hood release. My wife's 99 Explorer has been like that for 5-6 years. Sometimes I can do the push and then pull the release by myself, other times it takes two people. I have lubed the crap out of the latch and cable, but it makes little difference. Maybe loosening the latch and repositioning it would work, but I know how to open it now, so I never fixed it.
Old 04-17-2011, 11:24 PM
snorindad's Avatar
snorindad
got it open used a long flat blade screwdriver and pushed the secondary release over and lightly smacked it while holding it over then pulled the release in the cab and it poped open. used some lithium grease on the mechanism and worked it thru its paces a couple of times then tried the hood and seems to be fine now. Thank you all for your input I do appreciate it.
waltwin
6.7L Power Stroke Diesel
06-01-2017 09:58 AM
Kayleen Jenkins
Escape & Escape Hybrid
01-02-2017 06:08 PM
dixie460
10-27-2016 10:41 AM
powellbj
2017+ Super Duty
10-27-2016 08:54 AM
cletis
1999 to 2016 Super Duty
11-08-2009 07:54 PM
Quick Reply: 99 Ranger Hood stuck closed can't open
