99 Ranger Hood stuck closed can't open - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-17-2011, 07:40 PM
snorindad's Avatar
snorindad snorindad is offline
snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.snorindad has a very good reputation on FTE.
Just purchased a 99 ranger Friday. Just got home from a backpacking trip and my son tells me the hood wont open. Looking for suggestions on how to get it open can barley see the latch between the grill and hood. but there must be a way but I can't think of it right now. Any help would be appreciated. Thanks
Old 04-17-2011, 08:51 PM
justforkicks's Avatar
justforkicks justforkicks is offline
justforkicks is gaining momentum as a positive member of FTE.
is the hood latch inside the cab releasing the hood? or did the cable snap or what?
Old 04-17-2011, 08:53 PM
snorindad's Avatar
cable does not appear to be broken but it does seem to be stretched. Tried to pull cable and at same time pull up on hood but no luck.
Old 04-17-2011, 08:55 PM
snorindad's Avatar
While I was gone my son and a friend tried to get it open and I think they pulled to hard on the cable.
Old 04-17-2011, 08:56 PM
i'd say pull the hood release off and pull on the cable end with pliers or vice grips.
Old 04-17-2011, 08:59 PM
snorindad's Avatar
Are you saying to pull it from inside the cab? or is there a way to get a hold of it through the grill?
Old 04-17-2011, 09:04 PM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Quote:
I'm sure you already know this but the cable release in the cab only unhooks the hood. The safety latch on the hood still has the hood locked down. You have to push your fingers inside the engine compartment and move the lock to the left and then the hood will open fully. But I'm sure you already know that
Old 04-17-2011, 09:05 PM
well, i don't really know because my grill's already busted out so i can see mine plain as day. pulling the hood release inside off is less labor intensive and you'll know right away what's wrong with it. you may be able to get tools in from under the bumper in between the grill and radiator but go from inside the cab first because that'll tell you whether the cable's stretched, broken, or your release lever might just be screwed up. if the release mechanism itself is broken, you'll have to try and sneak in a pick or something to slide the release over to get the hood open.
Old 04-17-2011, 09:17 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
A bit of a longshot, but try pushing down on the hood while someone is pulling the release inside. It could just be jammed from being adjusted too tight.
Old 04-17-2011, 09:57 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
Like the above post says. It takes two people to open sometimes. Push down on the front edge of the hood 20-30 pounds of push then have somebody pull the inside hood release. My wife's 99 Explorer has been like that for 5-6 years. Sometimes I can do the push and then pull the release by myself, other times it takes two people. I have lubed the crap out of the latch and cable, but it makes little difference. Maybe loosening the latch and repositioning it would work, but I know how to open it now, so I never fixed it.
Old 04-18-2011, 12:24 AM
snorindad's Avatar
got it open used a long flat blade screwdriver and pushed the secondary release over and lightly smacked it while holding it over then pulled the release in the cab and it poped open. used some lithium grease on the mechanism and worked it thru its paces a couple of times then tried the hood and seems to be fine now. Thank you all for your input I do appreciate it.
99 Ranger, I could use some vacuum line help dixie460 Ranger & B-Series 3 10-27-2016 11:41 AM
Hood wont open Vinford 6.4L Power Stroke Diesel 4 02-06-2014 08:44 PM
1976 F-250 Hood stuck cubanforever16 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-18-2012 01:11 PM
Hood safety latch cletis 1999 to 2016 Super Duty 3 11-08-2009 08:54 PM
Help Can't Open Hood TheDuke 1999 to 2016 Super Duty 4 10-30-2008 12:44 PM
Tags
1997, 1999, closed, compartment, engine, ford, hood, jammed, latch, mustang, open, ranger, shut, stuck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
