1989 F-150 300 i6, 4 speed 4x4. Won't start. - Ford Truck Enthusiasts Forums
Old 04-17-2011, 07:08 PM
bopinc bopinc is offline
bopinc is starting off with a positive reputation.
I drove my truck and after it sat for a week it now wont start. With the key in the run position, I have voltage to the coil. When I turn the key to the start position, the starter turns over but I no longer have voltage to the coil. It seems I have a short in the system somewhere. Can anyone help?
Old 04-18-2011, 07:45 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Don`t know but possibily bad ignition switch or dirty/loose plug connection to it. The ignition switch is bolted to the steering column under the dash.
Also check that the battery connections are clean and tight and that the ground wire from battery to engine is in good condition and connections are good.
wont stop turnen sassydog 1987 - 1996 F150 & Larger F-Series Trucks 0 07-25-2013 06:42 PM
'86 f150 4.9 I6 no spark problem surfkovo 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 04-26-2006 08:18 AM
Run problems 82 300 six. really stumped dcollier Ford Inline Six, 200, 250, 4.9L / 300 8 03-13-2006 01:28 AM
ignition problem browntruck 1973 - 1979 F-100 & Larger F-Series Trucks 15 12-29-2004 12:03 AM
No Spark 89 F150 ninerocket1 Electrical Systems/Wiring 3 11-10-2004 11:01 PM
Tags
1989, 300, 4x4, 89, custom, f150, f250, ford, i6, spd, speed, start, strat, stright, top, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
