302 Plug Gap increase/ Why?
Old 04-17-2011, 10:56 AM
ymeski56's Avatar
ymeski56
ymeski56 is offline
Der Postmeister
My 87' 302 call's for a stock plug gap of .044 w/ stock ignition system components. However for 302's only a few years newer, stock plug gap increases to .054 w/ stock ignition system components.
The engines use identical ignition components, down to the last part #"s & Identical spark plugs. Why the .010 difference in plug gap?
If you can answer that, you may have "all" my rep votes. I've been trying to find out how/why for years!
Well, how about 1/2 my rep votes?..........You will definitely a rep vote out of it!!!
Old 04-18-2011, 12:20 AM
SilverSport's Avatar
SilverSport
SilverSport is offline
I would go with it being for emissions sake??? Chrysler did the same thing for the PT Cruiser engine ..... but as a TSB for all model years .... so I have now idea what I should gap at for that car!
Old 04-18-2011, 12:35 AM
86F150302's Avatar
86F150302
86F150302 is offline
It was 92 that the gap increased IIRC and I think ford did it to increase some HP.
Old 04-18-2011, 08:47 AM
jas88's Avatar
jas88
jas88 is offline
A wider gap is generally used to fire a leaner mixture.
