Go Back   Ford Truck Enthusiasts Forums > Misc. > Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics SPONSORED BY:
  #1 (permalink)
Old 04-17-2011, 06:07 PM
EMTF150's Avatar
EMTF150 EMTF150 is offline
1996 Ford F-150
EMTF150 is starting off with a positive reputation.
1996 F150 - Aftermarket Stereo Issues
Hey All, I recently bought a 1996 F150. It came with a cheap aftermarket stereo installed. When I went to put in a better one I found out that the last owner hacked apart the wiring harness and had everything taped together. Since it's already cut apart I had just decided to just install the aftermarket stereo to the factory wiring. My problem is so far (with my friend google) I have found 5 different wiring diagrams and none of them are right. I tried to just match the speaker wires from the speaker to the head unit also, but that didn't work out too well either due to the fact that I still can't figure out which are the power wires.
Any help with this is greatly appreciated! TIA!
  #2 (permalink)
Old 04-18-2011, 02:54 AM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
2011 Ford F-250
My Garage
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
Try this...
'96 F150.
__________________
2011 F250 6.2L XLT Crew Cab 4x4, 3.73.
Golden Bronze Clearcoat Metallic
2012 Coachmen Freedom Express 292BHDS
ARE Z Series Cap & BedRug
Audio upgrade
  #3 (permalink)
Old 04-18-2011, 05:22 PM
EMTF150's Avatar
1996 Ford F-150
Thanks for the response, that was the closest out of all the wiring diagrams, but still the last 4 wires (for the back 2 speakers) don't match. I'm at wits end trying to get this back together. At this point i'm either going to go to the local pick n' pull and get a piece of the factory harness and getting the adapter kit, or just totally bypassing all the factory wiring and putting in new stuff. Thanks again though!
  #4 (permalink)
Old 04-22-2011, 03:56 PM
EMTF150's Avatar
1996 Ford F-150
Well I ran into another problem...I was able to find a factory harness at the u-pull yesterday and I was able to get it wired in no problem (matched perfectly), but now I have no power. I checked all my connections and everything was good. I took my voltage tester and checked all the power wires, and I found that I have 2 switched power wires, but no battery constant power...I also checked the fuses and all the fuses were good too...
  #5 (permalink)
Old 04-23-2011, 05:04 PM
EMTF150's Avatar
1996 Ford F-150
Well, I feel like a complete idiot....Today I figured that before I totally rip everything apart again, that i'd go and check all my power and connections again...Sure enough I only had ACC power and no constant, checked the inside fuse box and the fuse was still good.....then I had an epiphany! I remember that there was a fuse panel in the engine bay...nah, that couldn't be it, could it? Well sure enough, the only fuse that was blown in the entire truck was the one that fed the constant power to the stereo! After replacing the fuse, everything was perfect-o...wow, I feel dumb now lol
__________________
Dane
EMT/Firefighter/911 Telecommunicator
Current: 1996 Ford F150 XLT 5.0 "War Wagon II"
Past: 1996 Ford F150 XLT 4.9 "War Wagon"
Tags
150, 1996, 1997, 2007, 96, aftermarket, f150, ford, fuse, installation, problems, radio, replacement, stereo, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
