Removing Air Filter? 6.0 Liter Turbo Diesel? - Ford Truck Enthusiasts Forums
Old 03-19-2003, 09:17 PM
JW'S Toy JW'S Toy is offline
JW'S Toy is starting off with a positive reputation.
Question Removing Air Filter? 6.0 Liter Turbo Diesel?
Simple question, so try not to rip on me too bad but I read through the manual and they have a nice twist and pull example of removing the air filter from a Gas Truck. For the 6.0 is just says 3 little paragraphs about remove, clean, & replace. Well i unclip the 4 clips and it seems like the front where the air hose wants to come off but then I have the damn battery cable in the way and the entire housing will not budge how do I remove this damn thing? Is there any pictures for the air filter handicaps such as myself?
JW
Old 03-20-2003, 04:01 PM
ttt?
no one knows this?
Old 03-20-2003, 06:28 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
It certainly isn't easy, but it isn't as hard as reinstalling the filter!
There is a clip on the bottom of the filter that extends below the front and rear pieces of the housing. You need to push the front one forward and the rear backwards while slightly pressing the filter down to get it to release the clips. It helps if you can grown another hand or two.
Old 03-20-2003, 08:29 PM
psd tech psd tech is offline
psd tech is starting off with a positive reputation.
Mark, are you nervous that big brother is watching us in here?? These are my opinions-- not Fords
Old 03-20-2003, 11:24 PM
hitecdan's Avatar
hitecdan hitecdan is offline
hitecdan is starting off with a positive reputation.
Ford wrote a tech bulletin on it because it's not easy.
Old 03-21-2003, 07:12 AM
Quote:
I'm not nervous about it, I know it's true. I want to be sure all of you know that I am not a Ford spokesperson.
Old 03-22-2003, 01:20 AM
hitecdan's Avatar
Gonna be taking a trip VictorwithaC 6.0L Power Stroke Diesel 7 10-19-2016 09:39 PM
TS Chip reburn Rob K 1999 - 2003 7.3L Power Stroke Diesel 2 09-27-2016 07:15 PM
Local HD e4od vs JW econo? darknight 1994.5 - 1997 7.3L Power Stroke Diesel 53 09-01-2015 09:05 AM
4r100 Cooler bypass P/N? agsmv1 Clutch, Transmission, Differential, Axle & Transfer Case 2 06-24-2015 06:17 PM
FICM Testing Videos smokersteve 6.0L Power Stroke Diesel 3 08-06-2011 06:25 PM
Tags
07, 60, air, clip, clips, desial, diesel, f250, filter, filters, ford, liter, motor, transmission, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
