Schrader valve adapter for fuel rail
I need an adapter for the 460 FI fuel rail on an 88 F350 to install an electric fuel pressure sender. The sender is 1/8 IPS male.
A perfect adapter would be a female shrader to an 1/8" IPS.
The only solution I currently have is to cut the hose on a mechaical fuel pressure test gauge and splice in a hose bib to 1/8 IPS female. Thats an expensive solution!!
Has anyone else installed a permanate mount electric fuel pressure gauge???
How did you cut into the fuel fail?
Fuel pressure is a parameter I want in the cab on an FI engine.
Appreciate the input.
Believe all the ford family for any year use the same fittings.
By current idea is to simply screw an adapter onto the fuel rail pressure point and attach the sender to that adapter. This would be easiest way.
I realize I can cut into the fuel line anywhere between the HP pump and the injectors but that is not the simple solution.
The semi-rigid platic lines are still on the truck and I am not ready to get rid of the plastic junk and go to real lines yet.
I thought the summit adapter was a Tee with 2 hose bibs. I use one of those on our 73 440 Dodge Dart.
This F350 among other duties is the Dart Hauler.
on
Use this.
It comes with the gague that can stay under the hood and has two extra 1/8" NPT ports for extra gagues. I have this on my 5.8L and love it. Just unscrew the schrater valve and this screws right down in there
Sorry for the confusion
