Exploded view needed. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-17-2011, 02:36 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
PMDRACER is gaining momentum as a positive member of FTE.
Hey guys -
Got into a small fender-bender yesterday thanks to some moron. Anyway, it looks like the only thing that got messed up is the front bumper, plastic cover and maybe a couple of the brackets. Luckilly, everything else underneath is straight. Anyone know where I can get an exploded view of the bumper and bracketry?
1999 F-250 SD Lariat.
Thanks in advance.
Old 04-18-2011, 01:19 AM
ZBIGBIG19TH ZBIGBIG19TH is offline
ZBIGBIG19TH is gaining momentum as a positive member of FTE.
Try Ed sponsor here,
www.partsguyed.com
Old 04-18-2011, 09:30 AM
PMDRACER's Avatar
Thank you very much. Looks like a good start. Very much appreciated.
Old 04-19-2011, 09:25 PM
svo121 svo121 is offline
svo121 is starting off with a positive reputation.
The front bumper has 4 bolts that hold it on and the brackets behind the bumper (behind the chrome part) can be replaced each piece. The mounts on the frame are welded and if bent can be moved with a big adjustable wrench or maybe pipe wrench unless that are damaged to the point of replacement. Then its cut and weld time. Washers or shims can be used to true the bumper front to rear and the 4 bolts can be loosened up to move it left to right or up and down within reason. Good luck
Old 04-20-2011, 03:23 PM
PMDRACER's Avatar
Thanks for the replies, gents.
I got underneath last night and have come to the conclusion that only damage is to the passenger side. The 'U'-shaped frame horn bracket is bent a little and so is the single straight support bracket. Looks like I can salvage both quite easilly. Looks like only the chrome bumper itself and the plastic fascia needs to be replaced.
Diagrams show 'V' shaped brackets that go from the outside of the frame rails to the lower corners of the bumper. My truck doesn't have those and there doesn't seem to be any indication that they were ever installed. My '99 was built in March of '98, and I understand there were some changes made to the basic setup somewhere around September of '99.
1950 F1 dual wiper exploded view drchapman 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-20-2017 02:13 PM
Front Axle Exploded View h20_guy33 Excursion - King of SUVs 2 07-22-2013 06:54 PM
76 f150 blower motor illustration ncpspeed 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-03-2013 02:40 PM
King Pin Kit, NAPA # 262 1386 reamer 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-21-2005 11:33 PM
44 exploded view need greenbike1 1987 - 1996 F150 & Larger F-Series Trucks 1 11-06-2004 07:40 PM
Tags
03, 2002, 2004, 40, bumper, connect, diagram, engine, excursion, expedition, exploded, ford, front, sohc, transit, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
