Fuel pump problems? - Ford Truck Enthusiasts Forums
Fuel pump problems?
Old 04-17-2011, 02:21 PM
jmart08 jmart08 is offline
jmart08 is starting off with a positive reputation.
Fuel pump problems?
I have a 1991 f150 and the rear tank isnt working. It isnt priming when the switch is turned on so I assume it is the fuel pump. I just bought the truck a few months ago and it hasnt worked since I have owned it to my knowledge. The fuel gauge for the front tank just quit working also. Runs fine off of the front tank, just without a gauge, and the gauge works on the rear tank, just doesnt run. Could these two problems be related, or are they seperate problems altogether? Thanks for the help.
Old 04-17-2011, 04:08 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
More than likely separate problems altogether.
It could be the selector switch on the dash but more than likely a bad fuel pump and a bad sender.
By the way when you turn on the key it does not prime anything. The selected fuel pump runs for one second to re pressurise the fuel lines for starting
Old 04-17-2011, 05:29 PM
Thanks for the input subford. You pretty much confirmed my thoughts but I was hoping it could be something a bit more simple and cheap though.
Tags
1987, 350, 460, fuel, promlems, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
