Built I6 300 4.9, breather filling with oil
Hell, any knowledge would help. Recently got done building I6 front top to bottom. Thought I did everything right but seem to be getting a lot of oil in my breather filter. Only have about 1500 miles on it so far. Have my rings not had a chance to seat yet or what could be the problem. The engine itself runs great and pulls hard off acceleration. No smoke out the exhaust. Just a lot of annoying oil sitting below my tuck. I really hope I didn't crack the rings or install them upside down. I made sure to follow given advice from a builder on which way to put them. Thanks in advance.
on
You running a PCV valve I hope. Is it new?
Any of the oil passages clogged? Did you blow them out when you did the rebuild?
The Crankcase breather element is changed every 30,000 miles according to Maintenance schedule B.
It should not be dripping in oil at this early venture, unless there is severe blow by caused by something, (PCV Valve, defect in engine), or a return oil passage being plugged.
If you don't have a PCV valve installed, it really should be added. The valve goes toward the rear of the valve cover, and the hose goes to a manifold vacuum source, similar to the power brake booster.
Without the PCV valve, all your blowby will back up into the breather, causing oil to puddle there.
All engines have some blowby, no way around it. The PCV valve is responsible for getting the blowby gases seperated from oil, and feeding them into the intake to be burned off.
on
Gentlemen, i know i am digging up a thread from the past but i wanted to end this conversation with my findings. I totally forgot about this post so i owe it the courtesy to end it. Here is what i found to be the problem:
No compression in #1 cylinder. When i installed the water pump i was an idiot and used too long of a bolt and it ruptured the casting. Thus in turn broke the rings and didn't make for a happy engine. Rebuilt and put a sleeve in it, runs great now. Here is a picture and the latest on my build.
https://www.ford-trucks.com/forums/1...0-i6-done.html
LowcountryF150
79
03-04-2017 07:54 PM
Sean_Memphis
17
03-27-2016 03:35 PM
xc4jokestomper
05-01-2011 09:15 PM
phurst
01-06-2011 06:07 PM
TexasGuy001
17
06-26-2009 11:25 AM
