Starter won't stop running! - Ford Truck Enthusiasts Forums
Old 04-17-2011, 12:04 PM
smashclash smashclash is offline
smashclash is starting off with a positive reputation.
Unhappy Starter won't stop running!
So I just got done replacing my cap, rotor, and new plug wires. I went to put the key and start it up. Well, something must have broke/stuck because the starter won't stop turning the engine over. I backed the key out and took it out and the starter is still turning over. The key cylinder still "feels" ok. Nothing feels broken or stuck and it's resistance when turning it has not changed, however I'm stuck with a constantly on starter.
I just pulled the key cylinder out and nothing appears to be broken or stuck with it. I pulled the actuator rod back so it was no longer in the "run" position. I hooked the negative portion of the battery back up and the starter came right on trying to start it. Something is stuck somewhere.... Any ideas?
Old 04-17-2011, 12:25 PM
Rico47635's Avatar
Rico47635 Rico47635 is offline
Rico47635 is starting off with a positive reputation.
The solenoid.
Old 04-17-2011, 12:27 PM
how do I know it's the solenoid and not the ignition switch or something else?
Old 04-17-2011, 12:32 PM
Rico47635's Avatar
A small wire is connected to the solenoid. That wire is what tells the "juice" to flow from the battery through the solenoid to the starter. Disconnect this wire and reconnect your ground. If the starter starts doing its thing, you know there is a problem with the solenoid. If it doesn't, then you know the problem is somewhere between your ignition switch and the solenoid.
Old 04-17-2011, 12:34 PM
rschem rschem is offline
rschem is starting off with a positive reputation.
starter
I had a 1972 f150 when I parked it in the parking lot at work it seemed ok.When I tried to start it after work the battery was dead.When I tried to boost it The solinoid was stuck.I still don't know how this happened as there was no signs of tampering or breakin.I replaced the solinoid and everything was fine.
Old 04-17-2011, 12:57 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Quote:
Yes.... red/blue-stripe wire....
Old 04-17-2011, 01:21 PM
Solenoid changed, i'm good to go. Thanks everyone.
Old 04-17-2011, 02:26 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Quote:
If it's a cheapo replacement from an auto parts chain, it'll likely do it again. Most of what they sell are made in china, AKA junk. This is one item that it really does pay in the long run to get a genuine motorcraft brand replacement. So far, they haven't farmed out production to china.
Old 04-17-2011, 03:19 PM
Quote:
yeah, i was worried about that. i usually go to advance but figured i'd get a better quality one at napa. i got one from them but unfortunately it was made in china. oh well, next time it goes i'll locate a motorcraft one somewhere...
Old 04-17-2011, 05:36 PM
Rico47635's Avatar
That'll be $29.95 please! I accept Paypal and cash through the mail. No checks!
Old 04-17-2011, 06:17 PM
NAPA units used to be better quality, before they were made in china.
I have more faith in a 30 year old factory solenoid than I do a brand new made in china replacement.
Old 04-17-2011, 08:17 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
I used to use Napa as well, untill the made in china thing. It's still better than some of the china parts made for autozone.
If I have to use parts other than motorcraft, I usually buy WIX.
Old 04-18-2011, 12:46 AM
Ecfool Ecfool is offline
Ecfool is starting off with a positive reputation.
Actualy NAPA is still a good product. You just need to make sure you get the better NAPA/Echlin parts. NAPA has 2 different lines of products, their cheap stuff and the quality parts. In fact Carquest has same thing their "red" line and the better proffesional quality items. Also you need to get the qualty filters NAPA's top line listed as Gold and Carquest listed as Wix filter line. I will avoid Autozone, Pep Boys or O Reilies unless I am in a bind and cant get quality parts.
I have been turning wrenches for over 40 years and ran my own shop for 8 years prior to getting govt fleet maintenance supervisor position so I realize advantages of quality parts.
Old 04-18-2011, 07:06 AM
Old 04-18-2011, 11:56 AM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
Your other option, next time you need a starter is to buy one for a 1990 Lincoln Town Car 5.0L. It is a permanent magnet gear reduction style, half as big, twice the power and just use the solenoid as a starter relay. Archion can hook you up with PN for a new one. There is also one that fits a 7.5L, I have one on mine.
Column shifter stuck, won't start, sigh cliffrwarren 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 36 08-18-2016 12:09 PM
1990 F-150 won't start- ignition cylinder? DattMavis 1987 - 1996 F150 & Larger F-Series Trucks 1 09-15-2015 01:04 PM
Help! '84 F150 starter won't stop turning shadetree enthusiast 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 09-18-2014 04:39 PM
starter won't disengage Singing River Farm 1994.5 - 1997 7.3L Power Stroke Diesel 18 01-25-2014 04:51 PM
55' F100 Starter, Ignition, Solenoid....Hmmmm JoeSwing78 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 08-23-2013 06:53 PM
Tags
1990, 351, 85, e150, f100, ford, lincoln, ranger, running, solenoid, starter, sticking, stop, towncar, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
