SMOKES like a freight train at 2500 rpms
It idles great drives ok has a little stumble and a few buffs of smoke at the top of 1st 2nd and 3rd gear driving like an old man.If i drive it like i stole it no problem no stumble.
If in park engine at temp and i stand on the pedal itll smoke like a freight train out the exhaust and really doesnt wanna go higher than 2500 rpms.
smoke is white not lossing an OZ of coolant,Swapped out turbo with a new one no change and no codes Cleaned EGR valve no change/Replaced EGR no change Changed air filter no change
Checked FICM voltage appears fine 47-48volts.Batteries run at 13.8-14.2 volts.
If you have combustion leaking into the fuel rail it can affect the whole side. The proper diagnostic would be to pull the secondary fuel lid and check for bubbles while cranking. IF bubbles are present then remove each fuel line and do the balloon test to narrow down which side has the leak. That will save you some unnecessary labor and cost. If/when you have made the determination of a leaking injector then you can pull them one at a time and the offensive member will be readily apparent. The puzzling thing is not having any contribution balance codes, not losing any coolant, and only runs up to 2500 RPM's. I'm still wondering about the fuel pressure too. What are you code scanning it with?
bhennessee
11-22-2011 03:02 PM
josh'sdeisel
21
10-05-2011 10:39 AM
BobsF350
02-15-2011 08:15 AM
