main seal repair sleeve install? - Ford Truck Enthusiasts Forums
Old 04-16-2011, 08:34 PM
rolape2's Avatar
rolape2 rolape2 is offline
rolape2 is starting off with a positive reputation.
Ok, I think I need to put a sleeve on the end of my crank for the main seal. The seal surface is worn pretty good. I did clean surface with steel wool, it is pretty smooth. The rebuild kit did not come with one. Question, does the repair sleeve require a different seal or can I use the 1 that was in my gasket kit. I can get just the sleeve for $13.00. What does it take to install the sleeve?
Old 04-16-2011, 10:05 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
Some rear main kits do come with speedy sleeves..... Ford did, it also had the installation tool.
I used a hammer and the tool IIRC...... you must also seal the speedy sleeve to the crank with Permatex Aviation #3 sealant.
Old 11-16-2011, 09:13 PM
classicfomoco classicfomoco is offline
classicfomoco is starting off with a positive reputation.
Where would you find a sleeve?
I recently bought a repair sleeve for the rear main seal from rock auto. They are the only ones who carry this in my area. But the one they gave me had an inner diameter of 3.629". My truck, of course, is special, the outer diameter of the crank in the rear is 3.477". It's a 98 ranger with a 3.0 liter v6. Where do I get one????? I even called all my local ford dealers. Anyone else have this problem?
Old 11-17-2011, 09:23 AM
snaponprofile's Avatar
snaponprofile snaponprofile is offline
snaponprofile is starting off with a positive reputation.
You need ford part # F2TZ-6701-A
Have a read here, I didn't even use avaition cement on mine, just contact cement. Make sure you get it seated good.
How big of a job is a rear main on these? - Oilburners.net
Old 11-17-2011, 09:44 AM
rolape2's Avatar
Try Napaonline, they list the sleeve for your engine. Just make sure you select engine parts and gaskets on the left side, then your year, make , model, and engine size. Their description does not tell what it is for, so you have to make sure you have your engine selected to get right part. I prefer to go to store though, If I do get wrong 1 it is easier to return. autozone list 1 also. depends on whats in your area. As for paying for the install tool, it cost more the the sleeve. I just used a block of wood and "GENTLY" tapped "EVENLY" around edge until sleeve seated. Make sure sleeve does not stick out beyond end of crank, it will keep flywheel from seating all the way (I had this problem). Make sure you use locktite to keep sleeve on.
Old 11-17-2011, 10:58 AM
Quote:
The part number I listed comes with the sleeve, seal, tool, and everything needed to do the rear main. Get at your local Ford dealer.
Old 11-17-2011, 12:59 PM
rolape2's Avatar
Is that part number for the 3.0 V6, that is what that user was looking for?
Old 11-17-2011, 02:25 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
When I put the rear main seal on my former 2001 PSD, I had the tool but I found it easier to do with a short piece of 2x4 and a hammer.
Old 11-17-2011, 02:44 PM
Then it should be in the gas section
Quote:
I ended up doing the same, was alot easier. I just finished it off with the tool.
Installation of a "Speedi Sleeve" on a 351W Reed Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 11 07-12-2013 03:51 AM
sleeve for fuel line bio short bus 1999 - 2003 7.3L Power Stroke Diesel 2 11-20-2011 10:36 PM
rear main seal - wear flange nibiru Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 02-08-2011 08:08 PM
Damper Spacer/sleeve 66shortbed 1961 - 1966 F-100 & Larger F-Series Trucks 3 04-18-2010 11:23 AM
crankshaft repair sleeve tundraathome 1987 - 1996 F150 & Larger F-Series Trucks 7 02-17-2010 08:23 PM
Tags
1989, 351, 92, change, crank, explorer, ford, kit, main, rear, repair, seal, sleeve, speedi, tool, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
