I want to replace front rotors on my 95 F150 4x4, 5.8, ABS. I bought the rotors but from what I can tell the existing ones are integral with the hub. Parts store said they gave me correct part any thoughts ?
When I upgraded my rotors I accidently got 4wd rotors at first. Those bolted to a hub. When the 2wd rotors arrived I had to put in new bearing races because they were coated with the rest of the rotor. From my limited experience the 2wd rotors are part of the hub and the 4wd ones bolt on.
you have to pull the whole hub off and then hammer out the studs then the rotor will come off , then you hammer the studs back on through the new rotor !
