Project 90! - Ford Truck Enthusiasts Forums
Project 90!
Old 04-16-2011, 04:46 PM
jejdavis's Avatar
jejdavis jejdavis is offline
jejdavis is starting off with a positive reputation.
Project 90!
Well guys, getting really close to putting my truck back together and on the road again. So far this is the list of what I got
1990 Ford F-150 351W auto
Engine
351w
shaved crank (had 2thou wear)
getting block bored and decked as we speak
40 over Kieth Black flat top pistons
comp cam extreme 4x4 flat tappet cam
hardened push rods
comp lifters and timing set
pro comp 195 aluminum heads
pro comp roller tip rockers
edelbrock 351w performer intake
edelbrock carb
proform hei distributor
Rest
aeromotive fuel pressure regulator
rebuilt c6, getting shift kit put in
9" rear end with 3.50 gears
full equix (something like that) gauge set
long tube headers
right now i'm rebuilding the rear end, but will be posting pictures of the full build soon!
Old 04-16-2011, 05:07 PM
FlatBlak FlatBlak is offline
FlatBlak is starting off with a positive reputation.
Subscribed
Old 04-16-2011, 05:41 PM
JNM76 JNM76 is offline
JNM76 is starting off with a positive reputation.
Sounds like what I did to the 351W in my 82 f250, but I have a different cam. Runs like a champ though
Old 04-18-2011, 04:15 PM
jejdavis's Avatar
You also used the pro comp heads?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
