94 F-150 Drivers side front lean
Probably a coil or coil perch which is attached to the frame. Common issue with these older girls. Compare the passenger side frame/coil/coil perch with the drivers side, and see what doesnt look similar. doubt it's the shock, that doesnt support any weight. Mine sagged on the passenger side, and I found the coil perch was partially ripped/rusted away, and was "pitching" forward, which caused the front to drop. Don't let it go to long without repair though....if that perch breaks away, it wont be good.
While your at it, check the rear springs hangers. These too are prone to rust quicker than the frame, and are not really a big deal to replace (Ford dealerships carry replacement hangers/ perches because of this) If you can find a competent repair shop they can cut (the hangers and perches are rivited to the frame) and replace a set in under 3 hours. As edge said, check the Radius arm bushings, they tend to "clunk" when worn. And the usual, ball joints etc. Another thing to take a peek at is the pivot bushing that ties (pivots) the left and right front axle halfs together.
Storm Knight
1999 to 2016 Super Duty
01-10-2017 09:46 AM
badaz4570
01-24-2016 10:43 PM
Larry DeChant
05-11-2012 09:35 PM
