94 F-150 Drivers side front lean - Ford Truck Enthusiasts Forums
Old 04-16-2011, 04:04 PM
shane7209 shane7209 is offline
shane7209 is starting off with a positive reputation.
My son purchased a 1994 F-150 and the front driver side sags. It sits almost two inches lower than the right. I am not much of a front end guy. Is this a week or broken coil? Shock? Any ideas? Also it has the I6 engine.
Thanks
Old 04-16-2011, 04:58 PM
19Flareside95's Avatar
19Flareside95 19Flareside95 is offline
19Flareside95 is starting off with a positive reputation.
Quote:
Thanks
Probably a coil or coil perch which is attached to the frame. Common issue with these older girls. Compare the passenger side frame/coil/coil perch with the drivers side, and see what doesnt look similar. doubt it's the shock, that doesnt support any weight. Mine sagged on the passenger side, and I found the coil perch was partially ripped/rusted away, and was "pitching" forward, which caused the front to drop. Don't let it go to long without repair though....if that perch breaks away, it wont be good.
Old 04-16-2011, 05:10 PM
Thanks Flareside. Son is going to bring it back over in the morning and we will jack it up and take a look. Truck has 203000 miles on it. Told him we might as well look at replacing the entire front end. Anything else to look aout for?
Thanks
Old 04-16-2011, 09:57 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
I'd check the whole frame, pay attention to radius arm brackets.
Old 04-17-2011, 07:01 PM
While your at it, check the rear springs hangers. These too are prone to rust quicker than the frame, and are not really a big deal to replace (Ford dealerships carry replacement hangers/ perches because of this) If you can find a competent repair shop they can cut (the hangers and perches are rivited to the frame) and replace a set in under 3 hours. As edge said, check the Radius arm bushings, they tend to "clunk" when worn. And the usual, ball joints etc. Another thing to take a peek at is the pivot bushing that ties (pivots) the left and right front axle halfs together.
Front fender trim badaz4570 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-24-2016 11:43 PM
'60 F-100 Leaning bills86f150 1957 - 1960 F100 & Larger F-Series Trucks 8 02-15-2015 02:30 PM
Driver side front wheel further in... kinetic5876 1997 - 2003 F150 3 12-14-2014 02:14 PM
grease leaking from front driver side tire hub Larry DeChant 1987 - 1996 F150 & Larger F-Series Trucks 4 05-11-2012 10:35 PM
Front wheel wont come off! Drivers side front - all the lugs are off. Suggestions? 93XLT150 1987 - 1996 F150 & Larger F-Series Trucks 16 02-19-2011 09:47 PM
Tags
350, 93, 94, 96, bronco, driver, f150, ford, front, lean, leans, lower, sags, side, sits
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
