water leaking in on driver floor
Old 05-07-2015, 10:07 AM
LivingLarge's Avatar
LivingLarge
LivingLarge is offline
Originally Posted by Technologiq
I've noticed the seal around my windshield is starting to come up, I don't want to deal with this. I'm kind of bummed - it's still the original windshield with the kentucky plant sticker on it .
Any of you guys replacing windshields, I'd only ever change it out with a Carlite windshield.
Carlite is the maker of the Ford OEM
Old 05-08-2015, 05:39 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
RCKYMTN-PSD is offline
Wrong post oops
Old 05-10-2015, 12:14 AM
HiZ's Avatar
HiZ
HiZ is offline
Can you Not put the original glass back in?
Old 05-10-2015, 12:12 PM
rblank's Avatar
rblank
rblank is offline
Same issue here, but add in a rusty windshield frame too. How did you guys cover your GEM? Any pics?
Old 05-10-2015, 12:36 PM
LivingLarge
Twice the labor...
Old 06-21-2018, 03:49 PM
michaelg10's Avatar
michaelg10
michaelg10 is offline
Originally Posted by RCKYMTN-PSD
Have you had your windshield replaced or just bought this X? Windshields dont usually start leaking unless they have had a poor install sometime recently.
I have found grommets in the firewall, sunroof drains, heater box, etc. to cause this also.
Ever since I had the computer replaced at the dealership, I’ve been getting water leaking down onto the parking brake pedal and onto the floor whenever it rains. I never had a problem before, so I’m wondering if they forgot to put a grommet back in that would cause us
Old 06-22-2018, 05:12 AM
carbon coupe's Avatar
carbon coupe
carbon coupe is offline
If its the original, it will break getting it out.
I believe you can put a newer SD windshield in it. It will say SUPERDUTY in the fretting at the top though. Theres plenty of options. Also, I think you can get the KTP decals online as well. Just take pics of the original position and replace.
Be careful if you live in the salt belt, the seal bed will be rusty causing the leak. If you live in a sun state, it could be dried out and separated. Rust is the worst scenario. Theres a couple of threads on here about it.
Old 06-22-2018, 09:15 AM
03X's Avatar
03X
03X is offline
Same happened to me! It was a rust patch above the windshield. Bodyshop and windshield... cost me a lot!
ligito
1999 to 2016 Super Duty
12-06-2016 08:30 PM
TitanoBlu
1997-2006 Expedition & Navigator
05-26-2016 03:21 PM
RadioControlGuy85
04-22-2016 08:45 AM
Demonhawk
18
11-13-2015 08:58 PM
maples01
02-01-2013 05:08 PM
Quick Reply: water leaking in on driver floor
