2 Different parking brake cables? Pictures
Hey all,
I'm doing a brake job next week (rear bearings, drums, hardware, cylinders, lines, the whole nine yards) and I was looking at my non-working parking brake assembly and noticed this.
Parking brake NOT on:
Parking brake on and all the way to the floor:
Does it look like I have 2 different parking brake cables on there? Or are they just 30+ years out of adjustment? Should the equalizer bar be perpendicular to the driveshaft/frame?
The secondary cables are probably rusted, binding. One is not retracting fully. Perhaps sticking in the cable or in the brake retract mechanism. A good cleaning may free it up. With the brake assembly apart at the wheels you can pull and push the cable and it may free up. If they don't free up, replace them.
They are not the same ,i just put two new ones on my 79 f-100 yesterday. Along with all new brakes ,hardware and drums. I noticed that to and called in and ask them to check the numbers again , one is longer than the other one and calls for a different number. The old ones i removed were a short and long one. jim
D8TZ-2A635-C .. R/Rear Parking Brake Cable / Obsolete
D8TZ-2A635-D .. L/Rear Parking Brake Cable / Obsolete
Fits: 1978/79 F250 4WD / 1979 F350 4WD.
I found a coupla of each NOS in case anyone's interested.
jim collins: Since the OP has a 1978 F250 w/4WD, you cannot assume that an F100 will be the same inre to R/L specific cables.
While many rear parking brake cables are R/L specific, some are not, as it all depends on the application.
Mark that "sparkle" is WD-40. It's my low $ rustproofing
Bill or Mark do you happen to know the length of those cables? I found some at NAPA and I'm wondering if they're the right length for my truck.
Left Rear...#UP93203...Cable Length: 69.5"...Protective Housing Length: 45"
Left Rear...#UP93200...Cable Length: 65.5"...Protective Housing Length: 45.25"
Right Rear...#UP93199...Cable Length: 58"...Protective Housing Length: 37.63"
Right Rear...#UP93204...Cable Length: 62"...Protective Housing Length: 37.75"
I measured from the outside of the drum to the ball end up in the frame so I was unable to get the overall length. It was roughly 65 inches and they are the same length.Huh.
Anyway, you could look up your truck on Inline Tube's website get a part number and call them for a length. I'm sure they would give you that info so you get the right parts.
wyckedcombo17
195
05-15-2012 11:06 PM
indyF-350psd
03-27-2011 05:24 PM
FireBlue
06-20-2010 10:14 AM
