temp gauge acting funny - Ford Truck Enthusiasts Forums
Old 04-16-2011, 09:35 AM
short stack short stack is offline
short stack is starting off with a positive reputation.
i have a 94 f150 with an i6 and 5 speed. the temp gauge just started acting funny. now when the truck is cold in the morning, the gauge reads like it's all warmed up and normal. then when the truck warms up the gauge is pegged on the hot side. after a while, like 10-15 minutes of this, then the gauge just plops down to normal and reads normal till you shut off the truck. then after the truck cools off, it starts all over again. is there a way to check the gauge/ sending unit? where is the sensor located? all help would be greatly appreciated. after this started i've done a good flush on the system and all fresh coolant
thanks, mark
Old 04-17-2011, 01:51 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
The stock "gauges" on these trucks suck. Then sending unit is probably going bad.
Aftermarket gauges are a great investment.
As for the location of the sender I got this from google.(not an I6 guy)
"rear of the head right below the exhaust manifold..straight up from the starter"
Old 04-17-2011, 02:11 AM
75Three90's Avatar
75Three90 75Three90 is offline
75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.75Three90 has a great reputation on FTE.
sounds about right to me you hit it right on the head
Old 04-18-2011, 06:09 AM
thanks for tha answers. i found the switch, wow what a godforsaken place to put that! anyhow, i grounded the gauge and then it seemed to reset itself so the needle pointed to the cold side and it seems to be working normally now, go figure. again, thanks mark
Updated 1990 460 EFI. Need advice! GreenMachinee 1987 - 1996 F150 & Larger F-Series Trucks 21 12-04-2014 08:18 PM
1990 460 EFI running really hot!!! HELP!!! GreenMachinee 1987 - 1996 F150 & Larger F-Series Trucks 5 12-03-2014 04:57 PM
Gauge issues/Ground issue? jayro88 1968-2013 Full Size Vans 3 01-03-2014 09:00 AM
Aeroforce gauge display screen acting funny with cell phone charger 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 4 11-18-2013 02:11 AM
Temp Gauge Fluctuating rpatrick 1987 - 1996 F150 & Larger F-Series Trucks 13 05-18-2007 01:03 PM
Tags
1986, 1996, 69, bronco, f250, ford, gauge, guage, heat, hot, reads, sensor, start, temperature, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
