What rear end - Ford Truck Enthusiasts Forums
What rear end
Old 04-15-2011, 10:52 AM
Farmboypowerstroke Farmboypowerstroke is offline
Farmboypowerstroke is starting off with a positive reputation.
What rear end
What rear end would be in a 1993 dually? I don't know if its f250 or 350 two or four wheel drive. They would all be the same right?
Old 04-15-2011, 12:20 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
It should be a Sterling 10.25". I am not sure if the dually versus SRW are the same?
Old 04-15-2011, 01:48 PM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
DRW's are Dana 80's I am pretty sure... Dana's have a 10 bolt rear diff cover and Sterlings have a 12 bolt.
Get the 2 digit numeric code off the door sticker under "Axle" and look it up on the chart. Then you'll know the maker and gear ratio.
http://www.ford-trucks.com/article/i...de_Chart_.html
Old 04-18-2011, 09:34 PM
Phy's Avatar
Phy Phy is offline
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
Both my 93 F250 SRW and my 93 F350 Dually (cab & chassis) have Sterling 10.25s...
1949 F-3 front end and rear end swap Joshiggity 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-28-2010 08:06 AM
rear end kentruckf100 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-06-2010 08:44 PM
69-f100 rear end 69-f100 1967 - 1972 F-100 & Larger F-Series Trucks 12 01-30-2010 01:47 PM
rear end noise jw miller Explorer, Sport Trac, Mountaineer & Aviator 3 07-06-2009 11:37 AM
Changing out rear ends what ones work A92Van Aerostar 8 12-14-2003 05:40 PM
Tags
12, 1993, 1996, 93, bolt, end, f150, f350, ford, rear, rearend, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
