atf? ?? - Page 2 - Ford Truck Enthusiasts Forums
atf? ??
Old 01-13-2012, 12:42 PM
Chris72's Avatar
Chris72 Chris72 is offline
Chris72 is starting off with a positive reputation.
Our old 6.2 farm truck runs on mostly WMO or WATF. We do pour some diesel in the tank every now and then when it gets cold. been running like this for more years than I can remember. Filter the W___? and run it.
Old 02-07-2012, 10:38 PM
sam146 sam146 is offline
sam146 is starting off with a positive reputation.
i purchased a 5 micron filter for water filtration for making a test batch.
also i would recommend getting new atf and new motor oil and test those on small scale.
ATF or 5W-30S in fresh M5R2 Transmission? Troyus 1987 - 1996 F150 & Larger F-Series Trucks 3 03-07-2016 07:42 AM
Mobil-1 ATF for 4R100 kawika 1999 - 2003 7.3L Power Stroke Diesel 28 03-02-2016 09:39 PM
used atf in fuel tank sjwelds Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 27 07-01-2014 12:47 PM
Synthetic ATFs redman84 1994.5 - 1997 7.3L Power Stroke Diesel 16 04-26-2013 12:05 AM
ATF use in T-170 tranny jaswolfie Oil & Lubrication 6 12-19-2005 09:17 AM
Tags
62, absolute, atf, bg, biodiesel, blend, centrifuge, diesel, enthusiast, ford, illegal, pa, run, supply, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
