2002 ranger gets 20 mpg?? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-14-2011, 10:08 PM
john72ss john72ss is offline
john72ss is starting off with a positive reputation.
ok first fill up, 2002, 3.0 auto 2 wheel drive driving conservativly got only 20 mpg??? any suggestions? maybe has original plugs? whats a good plug for this engine?
Old 04-14-2011, 11:08 PM
mfp4073's Avatar
mfp4073 mfp4073 is offline
mfp4073 is gaining momentum as a positive member of FTE.mfp4073 is gaining momentum as a positive member of FTE.
sounds about right to me. I wish I got 20 in mine.
Old 04-14-2011, 11:10 PM
well i think its pathetic! my 1988 2.9 four wheel drive gets 20! i thought the newer engines would be better????
Old 04-14-2011, 11:59 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
I think that is what my little brother's 02 Ranger Edge gets, it's the super cab 2wd 3.0/ auto. What is the gear ratio in your rear axle? My brother has 4.10s in his truck, gearing does play a pretty big factor in fuel economy. I have heard of the 2.9 being famous for great gas mileage, especially with a manual trans.
John
Old 04-15-2011, 08:06 AM
grandmas77f150's Avatar
grandmas77f150 grandmas77f150 is offline
grandmas77f150 is gaining momentum as a positive member of FTE.
That's about right. On long trips I get about 20-22
Old 04-15-2011, 08:12 AM
smalltrucker's Avatar
smalltrucker smalltrucker is offline
smalltrucker is starting off with a positive reputation.
Quote:
Same here with a '03' 3.0L Auto in a Ext cab, 3.73 gears. About the same I was getting with the '05' 4.0L 4x4 manual w/4.10's. The 3.0's never know to be mileage champs.
Dave
Old 04-15-2011, 09:47 AM
i dont know what the rear end gears are but at 60 mph in overdrive the tach shows about 2100 rpm
Old 04-15-2011, 10:19 AM
To answer your plug question. Just get motorcraft replacements
Old 04-15-2011, 01:45 PM
Rangerman Stan Rangerman Stan is offline
Rangerman Stan is starting off with a positive reputation.
I second that nomination for OEM plugs. They will work the best.
Old 04-16-2011, 07:10 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Yeah, its about par, the 3.0L is not a new engine. The 3.0L is the Vulcan, which dates back to the 80's and to be honest, has not had any serious internal updates since then, it is still a cast iron block pushrod engine. It might get better mileage or at least more power had Ford opted to use the 3.0L Duratec in the Ranger, but that would have driven the price tag up.
Old 04-16-2011, 10:54 PM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
Quote:
sounds like 3.73's i have that gearing and am turning around 2,000 rpm in overdrive @ 55mph. with the 3.0 4.10's would be a better choice, that motor makes its power higher in the rpm range than some of the other ranger engines. my 4.0 at best has gotten 19.5 highway, mostly gets around 17. in town its about 15, and during the winter is 14-15. the 3.0 isnt know for great mpg, but it is known for being a long-life engine.
Old 04-17-2011, 11:46 AM
I've had both of the 4.0L's in basically the same truck and the new OHC motors do a couple of MPG better, somethink else to think about.
Dave
Old 04-17-2011, 01:33 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
Quote:
I dissagree, In my opinion the 3.0V6 would bennefit from a much higher gear such as a 3.08.
My dad's old 98 Taurus had the 3.0 Vulcan and cruised at lower rpm than his 2000 Ranger 3.0 auto 3.73 gear. Taurus did 25 average with 28 highway and Ranger does 19 average 22 highway. Weight is similar between the two.
I bought a 88 Ranger supercab 4x4 2.9V6 5speed with 3.73 gear new. I got 18 city delivering pizza's and 23 highway at 60mph, 20 average.
My 99 4x2 supercab 2.5 5speed 4.10 gear is not much better overall. I average 22 overall and if weather nice can hit27-28mpg at 60-65mph.
Old 04-17-2011, 01:42 PM
You do realize that car and truck gear ratios aren't equivalent right?
Old 04-17-2011, 01:53 PM
Exactly! that is why I said The Ranger could use a higher rear gear. The Taurus ran at a lower RPM at same speed than the Ranger. I would put $ on a bet if the 3.73 were swapped for a 3.08 the highway MPG would go up.
Is a cold air intake worth it? Want more mpg. Nitroman Explorer, Sport Trac, Mountaineer & Aviator 8 07-01-2012 09:43 AM
7.3 fuel efficiency, 2002 4x4 crewcab 02'250SD General Diesel Discussion 7 05-23-2012 06:22 PM
Thanks guys! MPG went up to 19 average! DROOPY209 1997-2006 Expedition & Navigator 17 06-28-2008 05:11 PM
Improving Fuel Mileage 51dueller General Automotive Discussion 4 04-12-2006 10:26 AM
Tags
2002, 30, 30l, 373, 40, gear, mileage, mpg, power, range, ranger, ratio, rpm, v6, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
