F*^&%$ HEADLIGHTS ARE THE DEVIL! - Ford Truck Enthusiasts Forums
Old 04-14-2011, 09:03 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Been havin a slight blinking issue with my headlights, but it was only once in a great while......Now its constant....I cleaned my grounds, the one where the starter relay grounds to, and the one near the D/S headlight....Is there another that I may have missed?
Untill I get the issue resolved, I can't drive after dark...
-Wes
Old 04-14-2011, 09:04 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
Volvo92906 is gaining momentum as a positive member of FTE.Volvo92906 is gaining momentum as a positive member of FTE.
As in, the lights are turning on and off intermittently? Id go for the switch.
Old 04-14-2011, 09:07 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
A new headlight switch will go a long way on fixing this,,
You see there is a circuit breaker in a headlight switch, and they get old, the contacts in the switch get old and have more resistance that builds HEAT, that heat is making your circuit breaker go on and off....
Imagine a "Special" kid playing with the headlight switch....or a set of LED's in a blinker socket.....They're blinking like a zillion times a minute...
-Wes
Old 04-14-2011, 10:44 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm Ohio Ford Farm is offline
Ohio Ford Farm is gaining momentum as a positive member of FTE.Ohio Ford Farm is gaining momentum as a positive member of FTE.
I would. Check the harness ware it plugs in the the harness that comes out of the cab. If its lose road vibrations could cause it to flicker, IF that looks good and tight, try to pull it apart and check for melted pins, There are body grounds for each headlight on the core support. You can try to install a jumper from the Neg battery to the P/S headlight ground. If all that fails then I would try a new switch. I had a headlight plug go bad and made it flicker .. but was only one side that blinked. I take it they flicker / blink both at the same time.
Old 04-14-2011, 10:48 PM
OFF-You are correct, they both flicker at the same time, randomly.....And even when the truck is shut off, parked....
-Wes
Old 04-15-2011, 03:49 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I would replace the headlight switch and then get a pair of relays for the headlights.
Old 04-15-2011, 10:12 AM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
Quote:
also plan on repalcing the main light switch pigtail as well they were really common to burn /melt in the middle
Old 04-15-2011, 10:14 AM
Ok....Looks like I getta dig in the dash for a while....UGH ....
Btw, whats the relays for?
-Wes
Old 04-15-2011, 10:22 AM
The relays take the load off the headlight switch, so it don't go out in another 25,000 miles.. Plus they say it makes the headlights a little brighter...
Quote:
-Wes
Old 04-15-2011, 10:28 AM
Quote:
Ahhh, I see....I thought they made them a smidge brighter....wasn't sure though....
Hmmmm.....I have the Sylvania Silverstars as is....So the relays will make them BRIGHTER?
-Wes
Old 04-15-2011, 11:49 PM
Seems to be a heat thing....I turn the lights on, they are fine for a minute or so....Then they heat up, they flicker....Lettem cool, they're fine...Till they heat up again....Any suggestions?
-Wes
Old 04-16-2011, 02:49 AM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
-Wes
Sounds more and more like the switch...did you ever replace it?
Old 04-16-2011, 02:55 AM
Gonna do that today....What is up with the heating/cooling of thelights and them flickering?
-Wes
Old 04-16-2011, 02:59 AM
zxwut?'s Avatar
Corroded, pitted, or arced contacts can heat up due to the high resistance they provide, which could cause a momentary loss of contact.
Dim Headlights tjmcb Ranchero & 1961 - 1967 Econoline 5 01-11-2014 12:22 AM
No brake lights,when headlights are on 78 & 87 Super Cab 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-13-2013 09:14 PM
2007 F-350 HEADLIGHT ISSUE JohnF350Outlaw 1999 to 2016 Super Duty 1 03-04-2011 04:47 PM
2008 F150 Headlight Question BlueOvalFan29 2004 - 2008 F150 6 08-24-2010 03:04 AM
Ground wire on headlight switch? ghunt 1987 - 1996 F150 & Larger F-Series Trucks 2 01-01-2008 07:45 PM
Tags
1979, 2001, andthunderbird, econoline, ford, headlight, headlights, intermittently, lights, random, starting, thunderbird, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
