F*^&%$ HEADLIGHTS ARE THE DEVIL! - Page 2 - Ford Truck Enthusiasts Forums
Old 04-16-2011, 02:00 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Ahhhh....I see....Good thing I snatched the one outta my 94'...
-Wes
Old 04-16-2011, 11:03 AM
jodaddy jodaddy is offline
jodaddy is starting off with a positive reputation.
Do you have high beam switch on the floor?
Old 04-16-2011, 11:06 AM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Did you read post #3?
Quote:
Originally Posted by SideWinder4.9l View Post
Gonna do that today....What is up with the heating/cooling of the lights and them flickering?
-Wes
Old 04-16-2011, 11:31 AM
You were correct....I skimmed it, therfore didn't catch the whole thing...My bad...
Anyways....Swapped the one outta my 94' into it, and it seems to work fine now....Just don't have high/low beams.....It's showing that it has the highbeams on all the time, even when the turn signal stalk is in the low beam position....Any ideas? I wanna just straighten this issue out before the cluster bezel goes back on...
Thanks btw, White 97 xlt
-Wes
Old 04-17-2011, 09:47 AM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
you need a multi function switch wes, do you have a spare out of your 94 you had?
Old 04-17-2011, 11:04 AM
had it, never pulled it though ......gonna hit the jy.....
-Wes
Old 04-17-2011, 11:10 AM
fdude64's Avatar
fdude64 fdude64 is offline
fdude64 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by White 97 xlt View Post
A new headlight switch will go a long way on fixing this,,
You see there is a circuit breaker in a headlight switch, and they get old, the contacts in the switch get old and have more resistance that builds HEAT, that heat is making your circuit breaker go on and off....
i would bet the new switch will fix the problem
Old 04-17-2011, 11:14 AM
A new switch is JUST a measely $115 from NPD....
-Wes
Old 04-17-2011, 11:17 AM
fdude64's Avatar
sorry didnt see the second page
Old 04-17-2011, 11:18 AM
It's all cool man....
-Wes
Old 04-17-2011, 12:49 PM
workaholic workaholic is offline
workaholic is gaining momentum as a positive member of FTE.
#$%^&* devil
Maybe headlight switch, Grab the switch and push on it in all different directions while the problem is occuring. Then mess with the connector plug where it plugs in (on the back of the switch) to see if anything changes.
Dim Headlights tjmcb Ranchero & 1961 - 1967 Econoline 5 01-10-2014 11:22 PM
No brake lights,when headlights are on 78 & 87 Super Cab 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-13-2013 08:14 PM
2007 F-350 HEADLIGHT ISSUE JohnF350Outlaw 1999 to 2016 Super Duty 1 03-04-2011 03:47 PM
2008 F150 Headlight Question BlueOvalFan29 2004 - 2008 F150 6 08-24-2010 02:04 AM
Ground wire on headlight switch? ghunt 1987 - 1996 F150 & Larger F-Series Trucks 2 01-01-2008 06:45 PM
Tags
1979, 2001, andthunderbird, econoline, ford, headlight, headlights, intermittently, lights, random, starting, thunderbird, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
