problem fuel gauge 87 E250 how solve?
Question: how do i fix the switch for two gas tank reader?
Situation: I filled the rear gas tank of my E250 ford van. It was $25.00 worth of gas. the sensor/gauge worked fine. Until i decided to test the front tank and pulled the switch and it showed empty. Then i switched back to rear tank only the gauge/sensor failed to work!
Solution?:
Solution?:
Thank you for the feedback. I checked the switch while my wife moved the switch. It clicks each time she made the switch so I think the switch is good.
Other gauges ARE in operation such as temperature of the vehicle.
Should I: 1) try to replace the gauge on the dashboard?
2) replace BOTH sensor/sender in both gas tanks?
Thank you.
you might start be testing the gage, with the instrument cluster unplugged from the vehicle, use test leads to connect one post of the gage to a battery, then connect the other side of the gage through a test light to the other side of the battery, you should have a reading on the gage. if you don't, skip the test light. if you still don't, gage is bad.
because both tanks seem to have gone bad at the same time, i find it unlikely that the senders both went bad at the same time. if the gage tests good, study the wiring, you'll likely find a problem there
I've unplugged the cluster and I tested with other cluster (other van part which I used to test). Everything worked EXCEPT the gas gauge.
I've looked at all wiring. All are original. No cracks or splits anywhere from what I could see.
Apparently, both sensor/sender went bad at the same time?
Its against my logic to say both failed at the same time, try sticking a probe into one of the sender wires as close to the tank as possible, connect your probe to one side of a test light and ground three other side of the test light, if you get a gage reading, your sender is the problem, but I expect you won't get a reading, in which case move closer to the gage and repeat this test until you do get a reading
F250 89
01-23-2017 10:13 AM
72Blazerod
11-25-2007 06:16 AM
