Replacing serpentine belt - Ford Truck Enthusiasts Forums
Old 04-14-2011, 05:51 PM
bmarthin47250 bmarthin47250 is offline
bmarthin47250 is starting off with a positive reputation.
92 F150 with the inline 6 300 and air
Help please. The existing belt is frayed and cracked, need to replace it.
Picked up the new belt and have tried a number of times to install it. Canít get it installed, like it is to short
Checked the length of it against the old belt. Old belt is slightly longer, inch to inch and a half, sure this is expected as it is old and stretched.
Any tricks or tips installing the belt?
Seems like I replaced the belt when I purchased the truck several years ago and donít recall having any problems putting it on.
Thanks!
Old 04-14-2011, 07:26 PM
Terry S's Avatar
Terry S Terry S is offline
Terry S is starting off with a positive reputation.
If there is not a spring loaded tensioner on the belt you can losen the mounting bolts on the alternator and release the tension enough to get the belt on then push the alternator back into position and tighten the bolts back up.
Old 04-14-2011, 09:40 PM
Truck does have the spring loaded tensioner.
Old 04-14-2011, 09:46 PM
Terry S's Avatar
Then you can use a wrench on the tensioner to release the tension on the belt making it easy remove and replace the belt. piece O cake.
Old 04-14-2011, 09:50 PM
AK Outlaw's Avatar
AK Outlaw AK Outlaw is offline
AK Outlaw is starting off with a positive reputation.
Quote:
This. Also, sometimes you've just got to do some man handling.
Old 04-14-2011, 11:41 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
A proper fitting serpentine belt should be a little on the snug side when installing it. The belt has to be lined up with all the ridges on each pulley before it comes close to fitting under the tensioner pulley. An extra set of hands or a really long breaker bar come in handy.
Old 04-15-2011, 05:27 AM
drjoe171 drjoe171 is offline
drjoe171 is starting off with a positive reputation.
as I recall, mine CAN go on 2 ways, or so I was told.
Water pump may even spin backwards?
Might have all been an old timer joke since it was my uncle who told me that.
so as I was drawing a diagram on the inner fender with a magic marker,
I bumped my head near a sticker that shows it exactly.
Hopefully a nice big lever will get that spring loaded tensioner out of the way and the belt goes on withOUT your fingers or glove.
Old 04-15-2011, 08:44 AM
White Max's Avatar
White Max White Max is offline
White Max has a good reputation on FTE.White Max has a good reputation on FTE.
Quote:
It sounds to me like you may have the wrong belt. 1" to 1 1/2" is a pretty big difference...belts stretch over time, but not that much. What is the part number on the new belt? Is the part number on the old belt still legible?
Old 04-21-2011, 09:18 PM
The numbers were completely gone from the existing belt.
Went to O'Reilly Auto Parts and they were very helpful. They tried the belt I had, had the same issue. Looked thru the stock and tried on 5/8 of an inch longer, still no go. Tried another that was a full inch longer and it fit.
Thanks for all the suggestions
Alternator Belt (V-belt) squealing on 1986 E150 6cyl 300.... common issue? WalterRoad Ford Inline Six, 200, 250, 4.9L / 300 6 08-01-2014 04:45 PM
Need Urgent Help-Belt/Alternator Troubles Subzero68 6.0L Power Stroke Diesel 11 04-26-2014 08:23 PM
belt wont fit???? 94flaresideon20s Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-11-2012 09:07 PM
5.8 winsor new belt tensioner & Belt will not fit, HELP! DGM 1987 - 1996 F150 & Larger F-Series Trucks 4 05-17-2012 07:36 PM
2 Belt Alternator Pulley on 71 F250 with 360 Big Skier 1967 - 1972 F-100 & Larger F-Series Trucks 18 06-18-2008 11:39 AM
Tags
05, 1997, 2008, 40, 46l, aerostar, belt, changing, explorer, f450, freestyle, replace, replacing, sd, sepentine, serpentine, serperpatin, velt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
